Horn won't work
Old Aug 23, 2002 | 06:07 PM
gaww's Avatar
gaww
Default Horn won't work
Before I drag my car to the dealer, could there be any possible reason that I could fix myself that is causing my horn to not work? I find it pretty pathetic that a one year old car of this caliber has a horn that doesn't work, especially since I almost needed it to get those dumb8$$ drivers from merging into me ont he highway. Thanks. :U
Old Aug 23, 2002 | 07:46 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Default Re: Horn won't work (gaww)
I'm not sure of the fix but getting at it is pretty easy, you just have to be extremely careful when removing the airbag.
I believe it's a 27Torx that will remove the 2 screws from the back of the airbag, then it's a matter of removing the 3 wires in the proper order :D :cheers:
Old Aug 24, 2002 | 02:55 AM
Gary2KC5's Avatar
Gary2KC5
Default Re: Horn won't work (Mean Green 2000)
I'm totally confused MG! I've pulled my front nose off 4 times (don't ask...well you can ask but be prepared for a long explanation) and have never had to pull the plug on the air bag (until today when I pulled off the right side front fender)
The horn is located bolted to the right front skid bar. I found mine loose and sitting on the closeout panel the 1st time I pulled the nose off.
It's all just screws that hold the front end on, just take off the right front fender close out panel and it's right there.
To Horn won't work
