C5 lowering
Old Sep 26, 2015 | 07:03 PM
thompsonc3's Avatar
thompsonc3
Default C5 lowering
Does anyone know of a video on how to lower a 03 vette on stock bolts
Old Sep 26, 2015 | 10:48 PM
zachaeous's Avatar
zachaeous
Default c5 lowering
Here is a link to video by Froggy:
Old Sep 26, 2015 | 11:03 PM
thompsonc3's Avatar
thompsonc3
Default C5 lowering
https://www.youtube.com/watch?v=EBb5KkMgfFU
Thank you for that. I guess what I should have said was a how to lower video. There are lots of videos for C6's but I can't seem to find one for the C5's.
Old Sep 27, 2015 | 02:19 AM
SG Lou's Avatar
SG Lou
C5 or a C6...it's the same procedure in the front, i think the rears are different ?
Old Sep 27, 2015 | 08:53 AM
ZigZag's Avatar
ZigZag
Hi, this worked for me. It has good pictures.
http://www.frankhunt.com/FRANK/hobbi...5_Lowering.htm
Old Sep 27, 2015 | 09:48 AM
thompsonc3's Avatar
thompsonc3
Default C5 lowering
Thank you very much. Yes that will work.
Old Sep 27, 2015 | 08:51 PM
bwill03z's Avatar
bwill03z
That write up said to use 18mm wrench on the top nut to keep it from turning but 18mm did not fit mine, it was too small. I ended up having to use a crescent wrench die to lack of tools. It worked though.
Old Sep 27, 2015 | 09:25 PM
bwill03z's Avatar
bwill03z
I just read one of the DIY posts on this forum about lowering on stock bolts. Apparently on the rear bolts they are different lengths and if you adjust them both to the same amount of threads showing then you have screwed up your corner weights.I wish I had read that before I lowered mine!!
Old Sep 27, 2015 | 10:21 PM
thompsonc3's Avatar
thompsonc3
Default C5 lowering
. Yes I kept mine the same measurement on each bolt and my height on each side was way off. Will have to readjust.
Old Sep 27, 2015 | 10:28 PM
bwill03z's Avatar
bwill03z
How exactly do you readjust? Measure from the chassis to the ground on each side and make the adjustments?
Old Sep 28, 2015 | 12:23 PM
thompsonc3's Avatar
thompsonc3
Default C5 lowering
I guess whatever the difference is I will just have to adjust on the bolt for that side. Adjust and try it.
To C5 lowering
