BCM Troubles?
Been there,,,, done that!!
IF,,,,, that fails,, yiu can also try this:
Take the car OUT OF GEAR,, chock the wheels!!
In the passengers foot well, there is a relay on the fire wall (above and forward of the BCM. It has FOUR WIRES (RED, PURPLE, yellow and yellow/black stripe.
IF,, the car is having a BCM Security issue, find the YELLOW/BLACK stripe wire on that relay and GROUND IT to chassis ground. That will BY-PASS the BCM starter disable part of the security protocol. Once that wire is grounded, try to start the engine. If it cranks and runs, you have a BCM Security issue.
You can also use a jumper wire and jump the relay RED to PURPLE wire.
NOTE & WARNING!!!!!!!
When you jump those two wires, the STARTER WILL CRANK the engine! If its in gear, the car will MOVE!!!!! If the key is in RUN, the engine will start and leave the building!!!!
If you jump the purple and red wires and nothing happens, you have a defective solenoid, connection or starter issue.
Another simple check is to examine the wires at the starter solenoid. They MUST be clean, tight and not burnt up!!
Bill
