Service Traction Control
Old Oct 13, 2015 | 09:37 PM
JEH03Vette's Avatar
JEH03Vette
Default Service Traction Control
Had my battery disconnected for a couple of days while installing a new stereo. Hooked the battery back up and now I am getting "Service Traction Control" on the DIC display. Any of you C5 gurus have an idea of what I need to look at? Car is a 2003 M6 with the F55 option. Thanks.
Old Oct 13, 2015 | 10:49 PM
JEH03Vette's Avatar
JEH03Vette
Originally Posted by 8VETTE7
How about if you start by pulling and posting ALL the codes? More than a dozen different conditions can cause that message. Question is which condition(s) do you have??
Post the H or C o HC that follow each 5 character code. List the codes under the sensor they are associated with. ie 10 - PCM or 28 - TCS or 40 - BCM.... etc....
If you have never pulled codes before here is how:
OR
http://www.c5forum.com/ayc/dtcdic.php
Thanks. I will pull the codes.
