Ported Throttle body problem, question.
Old Aug 25, 2002 | 12:13 PM
turboo2u's Avatar
turboo2u
Default Ported Throttle body problem, question.
I picked up a ported Throttle body from Breathless Performance Saturday at Corvettes at Carlisle. They also installed it, saying your RPM's will jump up after a few cold start-ups until the computer "learns" the new part. After 8 0r 9 cold start-ups, the problem still exits. Did I get correct information and should I disconnect the battery or do something else to remedy the situation. Thanx. :seeya
Old Aug 25, 2002 | 03:56 PM
carpe dm's Avatar
carpe dm
Default Re: Ported Throttle body problem, question. (turboo2u)
What is the "problem?" It won't hurt to disconnect the battery. :)
Old Aug 25, 2002 | 06:20 PM
turboo2u's Avatar
turboo2u
Default Re: Ported Throttle body problem, question. (carpe dm)
The problem is the idle jumps up higher than normal on a cold start.
Old Aug 25, 2002 | 11:01 PM
itsonlyairandfuel's Avatar
itsonlyairandfuel
Mine did the same thing, after about 15 to 20 cycles it was okay. When it was cold I would start it up, let it find its idle, then shut it off. Did this about three times on each start up in the morning. This sped up the process. It will work.
Old Aug 26, 2002 | 01:39 AM
turboo2u's Avatar
turboo2u
Default Re: Ported Throttle body problem, question. (itsonlyairandfuel)
Thanx for the info, I think the problem is solved.
To Ported Throttle body problem, question.
