Slipping Transmission
Old Oct 19, 2015 | 04:29 PM
johnson333's Avatar
johnson333
Active Streak: 90 Days
Default Slipping Transmission
Greetings,
I have a 98 corvette, automatic with 75k. I have owned the car a little over 2 months. I got a good deal on the car and knew at some point I would need to rebuild the transmission. This car is not a daily driver.
I recently flushed the coolant system and the car has sat for a few days. Today, I did about a 20 mile round trip. All was well driving to my destination, where I stayed for about 2 hours. When starting back home on the highway, I started to feel the slip in drive, all of a sudden I was at 4000 rpm doing around 50mph. To be concise I noticed as I limped home 2nd, 3rd and drive gears are going nowhere. 1st gear seemed fine, I suppose. No warning lights came on and the only thing displayed was high transmission temperature.
I pulled the codes and here is what I have:
P11626
U1064
U1040
U1176
U1160
B2282
B2284
U1064
B2283
B2285
U1096
U1064
In that order.
I am not mechanically inclined by any means. I guess its time to get the tranny rebuilt, any suggestions would be great.
Also I just noticed a few spots on garage floor about 3 inches in diameter. I am assuming it is tranny fluid. But not certain.
Thanks in advance
Jeff
Old Oct 19, 2015 | 04:30 PM
73Corvette's Avatar
73Corvette
Have you checked the fluid level? Changed fluid?
Are the codes you listed H codes or C codes?
Old Oct 19, 2015 | 04:38 PM
enoniam's Avatar
enoniam
The U codes are databus issues, the B codes are indicating some short circuits. Only power train code is the P code - I don't know what that one is. However for the tranny issue I'd try to check the fluid level before assuming it was rebuild time. Unfortunately in these cars there is no dipstick to check the fluid level. You basically have to remove the fill bolt while the engine is idling in park and see if you can put more fluid in while it is running until it starts to leak out of the fill hole. Either have to have the car on a lift or on jackstands and have a pump to pump the fluid up and into the tranny. Can get hand pumps that screw into the fluid bottles pretty cheaply at auto parts stores.
Old Oct 19, 2015 | 04:41 PM
73Corvette's Avatar
73Corvette
Changing, refilling, checking the A4 trans fluid HAS to be done a CERTAIN way... LOW fluid can damage your trans
I would strongly suggest changing your trans fluid before taking it anywhere...or driving it ANYMORE.
Here is a good Froggy vid
Old Oct 19, 2015 | 04:53 PM
johnson333's Avatar
johnson333
The codes are H
I had taken the car to have the transmission flushed but they would not even consider doing it because it was slipping. Something about detergents in the fluid after flushing could make things worse for the tranny if it needs rebuilt.
I suppose I will give it a shot. Im not feeling putting the car on jack stands with it started and getting underneath (GULP). Better make certain my life insurance policy is up to date.
Old Oct 19, 2015 | 04:56 PM
enoniam's Avatar
enoniam
Originally Posted by johnson333
The codes are H
I'd think they'd at least check the fluid level for you. With a lift it isn't that difficult. It is a bit unnerving getting under the car with it running...
Old Oct 19, 2015 | 05:17 PM
73Corvette's Avatar
73Corvette
The codes are H
If your LOW on fluid it could be slipping... need to get it checked and DON"T drive it until you know it's full of fluid or for sure your trans is trashed...
the H-codes are history codes... write them down and save them... for future reference then DELETE them all...
Old Oct 19, 2015 | 05:40 PM
johnson333's Avatar
johnson333
Thanks everyone for the fast response.
Old Oct 19, 2015 | 05:53 PM
johnson333's Avatar
johnson333
One more thing....
Is there truth that if I have the transmission flushed, the detergents in the new oil can screw up the transmission??
Old Oct 19, 2015 | 06:32 PM
73Corvette's Avatar
73Corvette
I would call in the BS crew on that deal.
I would say the worst that can happen would be that you waste a little time and money making sure your fluid IS or ISN'T the issue...
Old Oct 20, 2015 | 04:57 PM
IH8Mustangs's Avatar
IH8Mustangs
I would be willing to bet it's the 3-4 clutch pack. 95% of the time you have 1st and 2nd and nothing after that its a bad 3-4 clutch pack, unfortunately they're super common on these transmissions. Probably 90% of the 4L60E's I've done have been a 3-4 clutch pack issue. Low fluid would cause slipping in every gear not just 3 and 4. If it is the 3-4 clutch pack you will have burnt looking and smelling fluid.
And yes flushing a high mileage transmission can cause it to fail. The detergent in the new fluid can cause build up to break free and plug up check ***** and valve body traces causing failure. If your trans has 100k+ and has never been flushed I wouldn't recommend doing it.
Time to buy an ATSG manual and learn about the internals of your trans!
Old Oct 21, 2015 | 11:54 PM
lionelhutz's Avatar
lionelhutz
I'd bet on the the 3-4 clutch being toast too.
Old Oct 23, 2015 | 10:06 AM
Martinez310's Avatar
Martinez310
Veteran: Marine Corps
St. Jude Donor '14-'15,'19
same happened to me the transmission mechanic told me my 2nd and 3rd gear was burned and bend so i decided to rebuild the whole transmission .. cost me a pretty penny
Old Oct 23, 2015 | 11:17 AM
slow-v6's Avatar
slow-v6
I had a similar experience after changing the fluid/filter on my 98. Didnt refill properly. Went though it step by step and it worked fine. When I was having the slipping issue, I noticed my tranny temps were higher then before.
Old Oct 23, 2015 | 09:31 PM
Chris Stewart's Avatar
Chris Stewart
Yep, needs a 3/4 clutch. They're only about $100 in parts, but you can quickly spend alot more while you're in there. A decent overhaul kit is about $300. Here's one for example.
http://www.trutechtrans.com/TT4L60E-...L1-Basket.html
It's not that hard, look even a 3 year old can do it.
Old Oct 24, 2015 | 05:18 AM
johnson333's Avatar
johnson333
Greetings,
Thank all of you for responding. Now the question is, do I have the transmission rebuilt or buy a gm certified re-manufactured transmission. All advice welcome.
Thank you
Old Oct 24, 2015 | 09:17 PM
zachaeous's Avatar
zachaeous
Default transmission
Greetings,
Thank you
There are a lot of transmission shops around but I would check their reputations and warranty policy fully before going with one. The GM rebuild runs around $2000.00 depending upon the pricing you get. I am sure the GM rebuilds would have all the latest upgrades that GM recommends. IMHO I would get mine rebuilt with someone I checked out their reputation and warranty policy. Good luck with your repair.
To Slipping Transmission
Old Oct 26, 2015 | 03:02 PM
enoniam's Avatar
enoniam
Since you are getting slipping in 2nd gear as well as 3rd and 4th it isn't just the 3-4 clutches. Did you ever get the fluid level checked? If your 3" spots on the floor are indeed tranny fluid there's no telling how low your fluid may be as you may have lost a lot more elsewhere. What color is the fluid on the floor? Is it reddish?
Old Oct 26, 2015 | 03:36 PM
johnson333's Avatar
johnson333
I have not had time to get the car up and check the fluid. I would say the fluid on the ground is a reddish brown. Definitely was not gear oil, I know that smell. I started to store the car for winter, hoping to take some vacation days this week and get the car up in the air.
If it is transmission oil, which I believe it to be, and it is low, how could it leak out? I am guessing the transmission pan. I hope there is no more to this than just a master rebuild kit.
Thank you
Jeff
Old Oct 26, 2015 | 03:43 PM
enoniam's Avatar
enoniam
Thank you
Jeff
Besides the tranny pan there are two lines running forward to the transmission cooler in the radiator. Besides the fittings on each end of the lines there are fittings for each line near the engine's bell housing allowing the lines to be split - at least there are on my 2000. Fluid could also potentially be coming from the tranny//torque converter interface as well as possibly around the tranny//differential interface. Hopefully it is an issue with the pan and then secondly with one of the tranny lines as those would most likely be the easiest and cheapest to rectify.
