I hope there is no more to this than just a master rebuild kit.
Jeff
Since you are not mechanically inclined I'd be hoping it wouldn't be a master rebuild kit. With labor to remove and replace tranny, plus rebuild labor, you are likely looking at a $2000-$3000 job.
I had talked to several transmission shops. The highest being between $1800 and $2200. The lowest between $1400- $1900 including torque converter, and another said $2000 to put in the re-manufactured transmission. The decision again is re-manufactured or have it rebuilt to future proof? I am on a fence.
I certainly wouldn't pull the trigger on either until figuring out if the fluid level is a problem and if so where it's leaking.
If you need to pull it and get into it the question then centers around what makes it future proof for you. Keep in mind the so-called "soft parts" in transmissions are always subject to wear. You can't really make them future proof. There are improvements that can be made but usually when building up a transmission to handle more power the "hard parts" that aren't subject to wear but are subject to breaking are replaced with stronger pieces. You can buy built up transmissions for double the amount of money you are talking, and then you'll have to pay for someone to pull the old one and put in the rebuilt. A standard rebuild will be fine if you plan on keeping the engine at stock power levels.
Thank you very much, I certainly appreciate your wisdom. I will check the fluid myself this weekend. I had several mechanics say that even if the fluid is low, that it would not slip that much. I do not know and I am trusting all the advice I get here on the forum. I believe it was a level iv transmission that I saw for $4000 and some change. I doubt I would ever build up the motor for that. However I have been pricing superchargers, but that is a small fortune in itself.
I'm not an expert, but I have rebuilt a few 4L60s. I would think that if the pump isn't picking up fluid there's no way it's going to get enough pressure on the 3-4 clutches in the higher gears or the servo in 2nd gear to be able to do very much at all but slip very easily.
