How much skill required: RPM diff install
Old Oct 24, 2015 | 06:24 PM
xdmikey's Avatar
xdmikey
Default How much skill required: RPM diff install
Just wondering how many wrenches(skill ratings)it is for the install on the stage II diff. Also, would retuning be necessary on an m6?
You may say "From your questions, too much for you, but I have a buddy who has great skills" so I won't be going solo here.
This is a future project since I have to replace the motor in my truck first.
Thanks.
Old Oct 24, 2015 | 06:44 PM
onspeed's Avatar
onspeed
If you can replace a motor you can change the diff.
Old Oct 24, 2015 | 09:09 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
not bad at all. with the right stuff, about three hours work. here's when i did a diff swap just recently
http://www.corvetteflorida.com/forum...d.php?t=104914
Old Oct 25, 2015 | 09:06 AM
feeder82's Avatar
feeder82
No retuning required. Not hard to swap, if you have a 2 post lift and a tranny jack its easy.
Old Oct 25, 2015 | 11:53 AM
xdmikey's Avatar
xdmikey
Jack and jack stands is where we are. This will be after replacing the motor in my truck. Truck is my DD.
Time and equipment(special oils/lubes for vettes)? The complete unit comes filled and sealed, correct?
Many thanks to everybody.
Old Oct 25, 2015 | 08:51 PM
Patches's Avatar
Patches
It's the same process as replacing it with a stock unit. The RPM diff does NOT come filled. They will not ship full of diff fluid so you need to get something like Amsoil, Royal Purple or fluid of your choice. I have swapped diffs in manual and autos and it's pretty much the same except for the seal plate that must be transferred on the auto diff. No retuning is required since the speed takeoff is from the diff passenger output. I would get some new seals and the main tranny-diff O-ring while you're at it.
Here are links to Dope's How-to:
http://home.comcast.net/~dopemaro/C5...ar_install.pdf
https://www.corvetteforum.com/forums...all-guide.html
Old Nov 1, 2015 | 02:28 PM
flyingillini's Avatar
flyingillini
Doc links broken, anyone have fresh links ?
Old Nov 1, 2015 | 04:32 PM
Patches's Avatar
Patches
That just happened - I checked those links a couple of minutes before I posted that. I believe I have the file saved on my computer in my home office. I'll see if I can post that one.
Here you go.
To How much skill required: RPM diff install
