Code P1626
Old Oct 27, 2015 | 03:34 PM
Robert Perkins's Avatar
Robert Perkins
Default Code P1626
1998 vert 65K miles. About every two weeks I check the codes on the car to see if there are any problems hiding. Today I had one code 10-PCB P1626 H Theft deterrent system fuel enable circuit. What would cause this code? Thanks in advance for any help.
Old Oct 28, 2015 | 01:49 PM
Robert Perkins
No suggestions or ideas?
Old Oct 28, 2015 | 02:04 PM
zachaeous's Avatar
zachaeous
I was having a similar issue in the VATS system with code P1626 and it was the pellet in my key not reading properly. I replaced the key and all was well with my car. I first tried cleaning the pellet imbedded in the key, that did not fix the problem thus the replacement key. All is well with my VATS system now. Hope this helps.
Old Oct 28, 2015 | 04:58 PM
dadaroo's Avatar
dadaroo
Old Oct 28, 2015 | 07:18 PM
Robert Perkins
I cleared the code took car for a ride checked codes and checked before shutting car off code was back with the C. The car ran fine with no problems observed, just do not want to be stranded.
Old Oct 28, 2015 | 08:20 PM
Robert Perkins
No other codes, checked my key it is 11.60 should be 11.80 but is within tolerance. Spare key is 11.76 I will start using the spare key and order a new one.
Old Oct 29, 2015 | 06:14 AM
dadaroo's Avatar
dadaroo
Here are the TD diagnostics you need to use.
https://www.dropbox.com/s/61fj6jldkt...stics.pdf?dl=0
Mr. Sam
To Code P1626
