Help troubleshooting wiper problems
Old Nov 1, 2015 | 02:28 PM
pmr2000's Avatar
pmr2000
Default Help troubleshooting wiper problems
Just picked up a bone stock 63k mile 2001 Coupe.
I searched and found quite a few threads for wiper issues, I cleaned out the 3 left and 1 right big udder. 1 of 3 left had some debris in there, the right one was totalled clogged looked like mouse nest....I made sure water now flows out and not leaking into wires or wiper motor.
Have not driven in rain since cleaning out the udders.
Issue is during rain in my wipers were periodically stopping in the up position, then stopping completed for minutes. No response from the stalk in any position but the wash button would always work. Then they would start working again in a few minutes no problem.
Any thoughts on how to 100% fix? Should I get a new wiper motor or stalk?
Thanks!
Old Nov 1, 2015 | 07:52 PM
pmr2000's Avatar
pmr2000
When the problem occurred 2x this past week while raining - turning stalk to any position, combination would not fix it. Appeared totally dead stuck in the up position both times. However the washer button would still work each time while experiencing the issue. Did not have a chance to restart car was on the highway. After a few minutes they restarted on there own if left in on position.
Wipers appear to work in the dry although have not attempted for long periods.
After searching posts I just cleaned out the udders yesterday both sides but did not particularly see any water although right udder totally clogged, 1 of 3 on left side had debris in there.
Did not take out wiper motor just vaccummed and blew out the area on both sides.
Have not driven it yet in the rain again since udder cleaning....any further advise would be appreciated!
Since it appears to be a trouble area hoping past experience here may pinpoint motor, stalk, computer, etc..from symptoms noted.
Thanks.
Old Nov 2, 2015 | 09:17 AM
pmr2000's Avatar
pmr2000
This morning pouring rain, during a hour drive wipers fine for first half hour, then would stop in any position for a few minutes, then start functioning normally for maybe 5 minutes, then repeats issue.
The wash function continues to work during the issue so wondering if that points to good stalk and bad wiper motor.
To troubleshoot the relatively inexpensive wiper motor appears to need removal so was think just swap out the wiper motor.
I realize I am breaking the just throw parts rule but figure it might be quicker at least for the wiper motor?
If it is electrical or stalk that would be a little more difficult / may need a shop......
Old Nov 2, 2015 | 04:39 PM
aj98's Avatar
aj98
parking in odd/wrong position could be a worn or bent parking pawl.
This thread
https://www.corvetteforum.com/forums...raight-up.html
shows the correct location for all the tabs.
Old Nov 3, 2015 | 09:34 AM
pmr2000's Avatar
pmr2000
This thread
Thanks, will refer to that post just in case...parking o.k. but I went for a autozone remanu wiper motor since only $55, will install and post back.
Old Nov 3, 2015 | 10:40 AM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
The wiper motor has a breaker in it that keeps the motor from burning out when there is high resistance on the windshield, such as snow. Either something is binding with the motor or mechanism or the wiper motor is just worn out. Replacement is easiest if everything else is good.
Old Nov 4, 2015 | 07:03 AM
dadaroo's Avatar
dadaroo
The fact that the washer function works would have nothing to do with the wiper motor circuits.
Personally I think your stalk is probably OK and the motor control board is the issue.
Here is a good DIY that may help.
http://www.digitalcorvettes.com/foru...d.php?t=121213
Mr. Sam
Old Nov 4, 2015 | 08:26 AM
pmr2000's Avatar
pmr2000
Great thanks I printed that one out.
I just swapped out the wiper motor last night, it does function but only time will tell if the intermittent problem is gone. $55 autozone remanu so figured worth a shot. One in there looks life a remanufactured one pretty beat up but did not open.
Last night on the way home before swap (2 days of rain) the wipers stop responding for the last 30 minutes of the drive - in the past would come back on after a few minutes so since they are working with new motor hopefully a good sign!
Old Nov 4, 2015 | 12:40 PM
dadaroo's Avatar
dadaroo
Hope that fixes it. Have not heard good things about some of those reman units. One guy had an issue later and opened it up and it was full of dirt and crap. At $55 not a big loss if it goes belly up.
Mr. Sam
Old Nov 9, 2015 | 09:21 AM
pmr2000's Avatar
pmr2000
Update - 1st day of rain and appears the autozone wiper motor is good, no problem with wiping during an hour drive.
The autozone swap looks better the the remanufactured one that was in in there, was dented, connection looked a little crusty, did not open the board.
One issue probably my fault - the intermittent setting stops in the upright position between sweeps, when the old motor died it was in the upright position.
New one will park down, just pauses in the up position...any tips on correcting, do I need to remove, or maybe loosen the shaft and push the transmission arms?
Thanks.
Old Nov 17, 2015 | 12:13 PM
Leo333's Avatar
Leo333
6th Gear
Wiper Motor Removal Procedures
Page 1 of 4 1 2 3 > Last »
submit to reddit
Old 05-27-2007, 02:12 PM #1
Bville-Bud
CF Senior Member
St. Jude Donor '05-'06-'07-'08
Bville-Bud's Avatar
Default Wiper Motor Removal Procedures
I had to replace my wiper motor, and thought I’d post my procedures. I’ll post up the pictures tonight. The whole process wasn’t very hard, but the wiper arms were a real bear to get off the arm studs.
Tools Needed:
Click the image to open in full size.
Hammer
Needle Nose Pliers
Small Common Screwdriver
Regular Common Screwdriver
T20 Torx
T30 Torx
Small Puller (I used a battery terminal puller)
Ratchet
Socket (10 MM Metric)
Socket (1/2 SAE)
5 inch extension
Parts Needed:
Wiper Motor
Removal
1. Remove 25 amp windshield wiper fuse (fuse 10) in the passenger’s side fuse box.
2. Disconnect the windshield washer hoses from the wiper arms.
3. Remove screen tray connectors by prying the center the center section of the connector with a small screwdriver; this center section spreads the connector feet keeping the connector locked in. Take needle nose pliers and remove the outer casing.
4. Use a small screwdriver and remove windshield wiper arm nut caps. Use caution not to mar the wiper blade finish. The nut is very tight, penetrating oil sprayed onto the connecting nut will facilitate the nut removal. Remove the ½ nut underneath the cover.
5. Remove the wiper arm by using small puller, to press the wiper stud and pull up the wiper arm.
6. Carefully pull the wiper valley cover tray away from the windshield, start by pulling the corners free, where there is very little clearance between the windshield and the top corner of the fenders. Work from the corners to the center section.
7. Flip the cover over and rest on top of engine, be careful not to break the washer hose etc. This will expose the wiper transmission linkage, and the wiper motor attached to the linkage in the drivers corner of the wiper valley.
8. Remove the two 10 MM wiper transmission bolts on driver’s side.
9. Remove the 10 MM wiper transmission bolt on passenger side.
10. Remove the T30 Torx screw and lift the motor arm that connects the wiper transmission to the top of the motor.
11. Remove the three T30 Torx screws that hold the motor to the wiper transmission.
12. Carefully work the transmission free to expose the wiper motor, and move away from wiper valley. Use care not to damage the transmission arms during removal or storage.
13. Take wiper motor out of valley and turn the motor over, use a small common screwdriver to depress the locking catch, and remove the electrical plug from the motor.
14. Clean any debris out of the three rubber drain channels (udders).
15. Remove T20 Torx screw, and separate the wiper motor plate and rubber shield from the wiper motor.
Volvo V60 Cross Country
www.VolvoCars.com/US
Discover the Versatile and Sporty
Design of the V60 Cross Country.
Bville-Bud is offline Reply With Quote
Old 05-27-2007, 06:02 PM #2
Bville-Bud
CF Senior Member
Bville-Bud's Avatar
Added pics, don't forget to get yourself an expert crew chief to help with the project:
Consider The Accord
www.Honda.com/Toyota_Camry
Compare Side by Side:
Performance, Specs, Price & More.
Old 05-27-2007, 06:51 PM #3
MadTom
CF Member
MadTom's Avatar
Great job and damn well documented .
Did you modified the outlet of the three udders? Imo they are miserable constructed.
My wiper motor was awash and I found the three rubber drain channels (udders) blocked with mud and leaves. The lower port of the udders are miserable constructed.
I enlarged the outlet yesterday. Now the water and dirt will be will be sluiced down.
Tom
MadTom is offline Reply With Quote
Old 05-27-2007, 06:56 PM #4
Bville-Bud
CF Senior Member
Bville-Bud's Avatar
Tom
Thanks, glad you liked it. I did open up the bottom of the udders some .
Old 09-26-2007, 11:35 PM #5
RedRider98
CF Senior Member
RedRider98's Avatar
This will come in handy. Thanks for taking the time to take pics!
RedRider98 is offline Reply With Quote
Old 04-22-2008, 03:49 PM #6
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Support Corvetteforum!
Bill Curlee's Avatar
Bill Curlee is offline Reply With Quote
Old 04-25-2008, 12:12 AM #7
KiwiToni
Junior Member
KiwiToni's Avatar
gotta love this forum! hubby is now outside trying to clean his udders! we need the car sunday, and don't want the wipers going when they shouldn't, but we also want them to work when they should!
thanks for the help!
Debs
KiwiToni is offline Reply With Quote
Old 05-17-2008, 03:14 PM #8
valdeztke
CF Senior Member
Send a message via AIM to valdeztke
A god send!
valdeztke is offline Reply With Quote
Old 05-17-2008, 04:30 PM #9
thetaxman
CF Senior Member
good write up
my wipers came off easily, I guess I got lucky
thetaxman is offline Reply With Quote
Old 05-18-2008, 04:41 AM #10
tstar
CF Senior Member
St. Jude Donor '11-'12-'13-'14-'15
tstar's Avatar
Excellent write-up!!! I had to stumble through this last year, and this would have been very helpful!! Turned out the cam on top was not installed correctly and my wiper motor was actually good! So pay attention to how the cam is oreinted before you remove it...
FYI I believe the closed end design on the udders is to keep rodents out of the blower motor/cabin...
__________________
Tim
Pewter 99 Coupe MN6: Sold
tstarsvette@yahoo.com
tstar is offline Reply With Quote
Old 08-30-2008, 03:00 PM #11
NY~FX
CF Senior Member
NY~FX's Avatar
great writeup
- Just one Note - DON"T buy that POS puller, mine broke after pulling drivers side - what crap from Taiwan - get a better one or you will regret it.
NY~FX is offline Reply With Quote
Old 02-01-2009, 11:25 PM #12
VETTHOG
CF Member
VETTHOG's Avatar
I followed the instructions shown here, installed a new motor and everything went alright until I started the wipers and they don't work like they should Does anyone know What I did wrong?
VETTHOG is offline Reply With Quote
Old 02-02-2009, 12:03 AM #13
c5blkvetteguy
CF Senior Member
c5blkvetteguy's Avatar
Are your wipers in the wrong spot when they are in the park position (when delay is on)? Cam on the wiper motor is out of position. Mine is the same way. It will be my spring fix.
c5blkvetteguy is offline Reply With Quote
Old 02-02-2009, 12:37 AM #14
VETTHOG
CF Member
VETTHOG's Avatar
Quote:
I don't think they go to the park position, they just cycle and slam against the stops. They wont go to the park position no mater where I put the wipers. Another funny thing is when the delay is on, they pause in the middle of their travel for a second then start moving again
Old 05-23-2009, 08:40 PM #15
TEXHAWK0
CF Senior Member
TEXHAWK0's Avatar
Taking the motor out looks straight forward, but how do you re-attach the drive linkage so that the wipers stop in the right place? I think I saw a post somewhere on how to synchronize the cam. It would be good to get that information together with this so people have the complete job.
http://forums.corvetteforum.com/c5-t...iper-arms.html
TEXHAWK0 is offline Reply With Quote
Old 05-23-2009, 10:41 PM #16
rustyguns
CF Senior Member
rustyguns's Avatar
Send a message via Yahoo to rustyguns
i did it the old fashion way...trial and error
rustyguns is offline Reply With Quote
Old 05-23-2009, 11:32 PM #17
robsc501
CF Senior Member
robsc501's Avatar
Hi There:
I was wondering where do you buy the screen tray connectors?
Nice pictures & good instructions.
robsc501
robsc501 is offline Reply With Quote
Old 05-26-2009, 09:51 PM #18
mqqn
CF Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
mqqn's Avatar
Quote:
Originally Posted by robsc501 View Post
Hi There:
robsc501
Hi robsc501 -
You should easily be able to get those at your dealer - probably in stock and probably overpriced.
I would add to this nice write up, that there is one of the plastic pop-fasteners that is different than the other four - it is located right at the passenger side hump molded into the cowl cover.
Also, I was able to just soak the wiper arm bolts with PBlaster and then firmly grasp each arm and wiggle it up and off - protect the paint of the fender on the drivers side for safety.
Finally, try to get your hands under the cowl and push up on the pop-fasteners while squeezing them underneath to get them up and out of the holes.
best regards -
mqqn
__________________
RIP Burner
mqqn is offline Reply With Quote
Old 06-23-2009, 03:08 PM #19
SlammedC5
Junior Member
Is it ok to take the udders out or are they necessary?
SlammedC5 is offline Reply With Quote
Old 06-24-2009, 03:14 PM #20
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Quote:
As far as I know,,,there there to allow water OUT and to keep things from getting in. From my expierence,,,, things (mice) can get in even if the utters are in place. Yes, you can yank them. That doesnt mean that the holes they leave still cant get clogged. Check them every once in a while!!
Go Back Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Reload this Page Wiper Motor Removal Procedures
submit to reddit
Similar Threads
Thread Thread Starter Forum Replies Last Post
Rear Weather Strip Replacement Procedure Bville-Bud C5 Tech 36 05-19-2015 05:12 PM
C5 Hydro Carbon Fiber Wiper Arms & Cowl American Hydrocarbon C5 Parts for Sale/Wanted 36 08-31-2014 03:53 PM
COWL - WIPERS - "A" PILLARS on SALE! American Hydrocarbon C5 Vendor for Sale 6 06-14-2014 09:15 PM
White Carbon Wiper Arms! American Hydrocarbon C6 Parts for Sale/Wanted 1 06-14-2014 09:00 PM
My 75 progress pics Chuckster75 C3 General 13 10-01-2010 10:59 AM
Tags
2002, blade, c4, c5, control, corvette, cover, fuses, moter, motor, problem, project, removal, windshield, wiper, wsenior
« Previous Thread | Next Thread »
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Rules
Forum Jump
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Read more: https://www.corvetteforum.com/forums...#ixzz3rllkukj8
Old Nov 17, 2015 | 12:54 PM
pmr2000's Avatar
pmr2000
I would not take them out especially the 4th one on the battery side - they direct the water down. What I did was snip the bottom off about 1 inch so that they don't clog easy.
BTW since I replaced my motor the delay is in the "up" position, can't figure it out from the pics. They park fine when off. Just glad they are working after the remanu autozone one only lasted a day. So far so good with the brand new autozone one....
To Help troubleshooting wiper problems
