Here is a pic of my driveshaft. it was vibrating some so i pulled it for a look
the front shaft wobbles in the tube so i measured the bearing to tt bore and there is 1 thousand inch clearance. the bore in the tube looks like it took some damage from wobbling. what could have caused this i am going to put my shaft into another tube i have but worry it may happen again.
arrow indicates bearing where wobble in tube occurs
