Apparent Clutch Issue
Its fairly easy to remove the master cyl and replace it. It has a Quick Disconnect COUPLER that connects it to the Slave Cylinder.
IF,,,,,,,,,,, That isn't the issue,,, the slave cylinder is most likely bad and that requires complete drive train removal (Torque Tube, Tranny and Diff)
You can try to completely BLEED the system. That requires exhaust system removal and removal of the tunnel plate.
How any miles on the clutch? If you have to replace the slave cyl, its pretty much time to replace the Slave, pilot bearing, clutch, throwout bearing in one fell swoop!
Bill
I've read on here people who said they've done it on tall jack stands. That sounds no fun and I have to wonder where you put the rear ones since you have to removed (or at least loosen) the rear cradle. Also, I have a 4 post lift and wonder if that can be used since I have a trolley that I can place a jack in to get the rear of the car further up. Or will the lift's runways be in the way?
I've looked in the usual master threads for this job covered on here and done a quick search, but mainly found threads on vibration issues. Can someone point me to a good write-up that addresses these questions?
Thanks,
Doug
I did the entire job my self on jack stands. I use a floor jack and a motorcycle lift jack to do all the supporting and lifting
Job on a four post. Hmmmmm,, You still have to raise the rear to remove the rear cradle. Not difficult.
If you need a clutch, you most likely need a LOT of other things:
Differential Output shaft seals
Check the Torque Tube bearings
Check the Torque Tube Couplers
Before you do the job take an hour and check the condition of the limited slip clutches. Jack up one wheel trans in N, other wheel on the ground E Brake OFF. Attempt to rotate the jacked wheel. You will be able to but, there should be a good amount of resistance as you are slipping the clutches in the rearend. If its very easy, you have issues in the clutches limited slip clutches or belivew springs. Do the same for the other wheel.
While you have a wheel off the ground, PUSH PULL at the 12, 6, 3 & 9 O Clock wheel positions to see if the wheel bearing is sloppy. Should NOT be any slop.
Here are my favorite differential post. They should provide you a LOT of info:
- C5, ragtopws6 , Upgrading your C5 rear with C6 Z06 guts, : http://forums.corvetteforum.com/c5-g...-z06-guts.html
- C5, Its_Go_Time, Output Shaft Install - Left and Right: http://forums.corvetteforum.com/c5-t...post1573407966
- C5 Differential Seal replacement: http://forums.corvetteforum.com/c5-g...on-photos.html
So for a daily driver convert like mine with flip-tie cold air mod and Borla exhaust, and no plans to add big power, is the Z06 clutch setup still the way to go? That's what our local Corvette specialist said, especially since it's essentially the same price as stock. Or are there better aftermarket clutch kits for the same price? If I go Z06, is the clutch master cylinder the same or different?
Lastly, I saw on Rockauto most clutch kits there include a new flywheel. I was just planning to have mine resurfaced unless that's not a good idea on these cars for some reason.
See:
redshift.homestead.com/Drivetrain1.html
One of the previous posts said you can't hold the car up without the
cradle, you just need jackstands under the frame! If you have one of
those new(my lift is 15yrs old) trolly jacks you are in good shape.
Lifting the car high enough above the lift IS the first trick!. I used
two big jackstands and a stack of timbers
I plan to do it without buying a tranny jack and working at a higher
level. I am building a custom dolly to hold the driveline and will raise the
lift to lower the driveline.
Any ideas or comments welcome!
C5GARY
Thanks,
Doug
Just make sure you do the entire CLUTCH SYSTEM. Slave, master cyl, pilot brg, throwout bearing, remote bleeder, pressure plate and disk .. It may be less expensive to keep the OEM flywheel, as its already balanced. make sure that you refference mark the PP to FW.
I also called my local Chevy dealer (the good one that sponsors our local Corvette Club) and they have a pretty good deal on the full Z06 clutch kit, cheaper than Tick but not as good as the Luk through RA. The dealer said the slave is a must but thought it odd I wanted the master cylinder, which they don't even have in stock. They confirmed in 2002 there is only one listing for the clutch master across all Corvettes...wonder if this is like the intake manifolds in 2001+ cars, where base and Z06 are same?
So I figure I'll get the clutch master later if needed since it's not part of the driveline R&R. Appreciate thoughts/experience on the Luk vs. dealer OEM Z06 for a mostly stock convertible daily driver (my mods are mainly focused on handling).
Doug
Still wonder if the Luk clutch is indeed OEM. If so, guessing their "Pro Gold Performance" is Z06??
