A/C button/light
Old Nov 11, 2015 | 08:32 AM
huesmann's Avatar
huesmann
What about when it's really cold in the winter, to warm things up quicker? Seems silly to use AC for that.
Old Nov 11, 2015 | 08:55 AM
pmr2000's Avatar
pmr2000
This is odd only car I have ever come across that does so
Just to clarify - if I want heat need to set top and bottom with no recirc?
Old Nov 11, 2015 | 08:56 AM
coia96vette's Avatar
coia96vette
I agree. You will have to ask the GM engineers about that one.
Old Nov 11, 2015 | 08:58 AM
coia96vette
Just use to auto function and set your temperature and let the computer do its thing. Had mine out last night and it worked fine even at 40 degrees out.
Old Nov 11, 2015 | 08:59 AM
huesmann's Avatar
huesmann
No, at least on mine, if you set top+bottom you can do fresh or recirc, without AC. Only bottom-only requires AC for some bizarre reason.
Old Apr 24, 2018 | 11:14 PM
klw97's Avatar
klw97
Default A/C glitches
Originally Posted by huesmann
New owner of a 2004 base here. What is the normal behavior for the A/C? I'm getting the A/C button/light coming on when I use the heater (and I can hear the compressor). On the "fresh air" setting I can sometimes turn it off, but on "recirculate" it only blinks for a bit and then stays lit. Is this normal? Seems wasteful when I don't actually want the A/C to run.
Thanks!
Mine just blinks when I push it. Manual says that means it is able to function at that time??? Why?? I did everything it said to in manual, it was 80degrees out and it would blink a few times then go off. Any ideas??
Old Apr 25, 2018 | 03:24 PM
grantv's Avatar
grantv
Low refrigerant? My first guess.
Old Apr 27, 2018 | 10:57 PM
klw97's Avatar
klw97
Default A/C weird
Thanks. How do I put an Avatar up?
