titanium help
Old Nov 4, 2015 | 12:49 PM
paul17's Avatar
paul17
Default titanium help
hi I found a local welder to do the bypass mod on my ti cat backs.
does enyone know what kind of titanium is used in the muffler system. he would like to know what kind of rod to use otherwise he will use a all Purpose rod thanks paul
Old Nov 4, 2015 | 12:58 PM
skar's Avatar
skar
Not sure but pure titanium would be a $$$ muffler.
Old Nov 4, 2015 | 01:05 PM
paul17's Avatar
paul17
I don't understand all whats involved he just wants to use the correct welding rod I am sure its not pure titanium thanks
Old Nov 4, 2015 | 01:22 PM
skar's Avatar
skar
When they weld titanium at work its done in s vacuum .
Military grade or pure will catch fire in high temps .
We have fire extinguishers at work made for metal fires .
I ask our welder at work and he said its
Coated with titanium . ( titanium coated finish )Any mild rod should work .
Or it's not pure titanium Only a percentage in the muffler is titanium .
(A mix )
Old Nov 4, 2015 | 01:30 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Paul
The company that constructed the Ti mufflers is TIMET
Here is an article about the company, the metal and the product.
In it, it mentions that it used exhaust grade 2 Ti Metal. The PDF has a data sheet for all their products:
http://c.ymcdn.com/sites/www.titaniu...ember_2000.pdf
The TIMET exhaust
grade is a version of commercially pure titanium
similar to industrial Grade 2. It is produced at the
Morgantown, PA facility
Grade 2 data sheet:
http://www.timet.com/images/document...grades/50a.pdf
Hope this helps.
Bill Curlee
Old Nov 4, 2015 | 01:33 PM
paul17's Avatar
paul17
thanks people I knew I could count on you
Old Nov 4, 2015 | 01:36 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Ti in our muffler is pure Ti metal. It can easily be welded if you have the correct Wire, welding tips, shield gas and the set up to purge the pipe.
The shield gas is used to remove the OXYGEN from the weld arc and molten metal. The shield gas has to be on the outside and inside of the welded pipe/muffler. Ti doesn't catch fire. It oxides very readily in oxygen and turns into slag (BIG HOLE) if shield gas isn't properly surrounding the weld.
Old Nov 4, 2015 | 02:30 PM
skar's Avatar
skar
It can catch on fire .
Google it . Lot on this .
And I have seen it catch on fire .
Super Bright white .
Old Nov 4, 2015 | 04:10 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I know MAGNESIUM will catch fire and when it burns it is super bright white.
Titanium does not. Like I stated previously, It has to have an ARGON Shield gas to purge out the oxygen and nitrogen in the air when it is welded.
If you don't use shield gas, the weld gets contaminated, brittle and weak. It also can burn through and crumble.
If you can find me an article in GOOGLE on Ti fires, I will surely read it..
Here are two of the best TIG Welders out there on welding Ti metal.
MR TIG!
Oh,,,, Here's a MAGNESIUM FIRE!!
Old Nov 4, 2015 | 04:55 PM
skar's Avatar
skar
I was machining it today on a lathe . Chips from a finish pass .002 ( like steel wool )
Will burn with a bic lighter . When machining you need to keep cutters sharp if they get dull
Friction can start a fire . And you need Fire extinguishing made for metals .
I have seen this happen . I don't think a car exhaust would get a hot enough to do this .
Unless a drive shaft was rubbing on it or dragging on the pavement and even then doubtful .
Turbine engines have caught on fire because of the titanium parts failing ( friction )
www.youtube.com/watch?v=IU7A1KS28i0
https://www.fire.tc.faa.gov/pdf/fsr-0457.pdf
Old Nov 4, 2015 | 05:10 PM
skar's Avatar
skar
Old Nov 4, 2015 | 08:54 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
OK SKAR,,, Forum emotioncon list doesnt have a BOW DOWN smiley..
This will have to do
I guess Ti can burn.
BC
To titanium help
