suspension upgrade need help
Old Nov 15, 2015 | 02:05 AM
Gangsta_Vette's Avatar
Gangsta_Vette
Default suspension upgrade need help
hello guys
i have a 2001 c5 coupe i been looking into buying some suspension parts. car sees more street then track (drag strip) . my question is wat do u guys recommend to go with coil overs an get rid of the leaf springs or drag shocks . car is not a daily driver an am on a budget
best bang for the buck guys let me kno wat u guys think ,an car has full exhaust ,cam,ls6 manifold an cold air intake an pushing around 420rwhp give or take
thanx
Last edited by Gangsta_Vette; Nov 15, 2015 at 02:08 AM. Reason: forgot other stuff to mention
Old Nov 16, 2015 | 05:07 PM
SaberD's Avatar
SaberD
It sounds like your goal is mostly to have a solid rear for drag?
For a budget build, coil overs should be out of the question.
Old Nov 17, 2015 | 12:07 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Just beef up what you have. Add a good used C5 ZO6 spring and swaybar with some C6 ZO6 Shocks....
OR
Get some WIDE rims and tires and go for the C6 ZO6 Suspension. There CHEEP on the parts for sale and will put a SMILE on your face and a new step in your suspension..!!
Old Nov 17, 2015 | 12:58 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Check out Gene Culleys suspension kits:
https://www.corvetteforum.com/forums...rformance.html
Old Nov 17, 2015 | 09:41 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
Thank you for the referral. We do recommend the C6 Z51 sway bars along with the C6 Z06 shocks for the C5's.
Old Nov 18, 2015 | 09:42 AM
HiVoltge's Avatar
HiVoltge
St. Jude Donor '08
upgrade to Z06 springs and a thicker tunnel plate as well as the obvious shocks and sway bars. It will make a huge difference
Old Nov 18, 2015 | 12:19 PM
ArtGle's Avatar
ArtGle
Veteran: Marine Corps
Default Cultrag suspension 'upgrade'
See the picture.
Bought this from Gene back in 2014 early in the year.
Installed it and been Happy as a Bug since.
Great Price.
Handles like a Slot Car...
Old Nov 18, 2015 | 12:20 PM
ArtGle's Avatar
ArtGle
Only other recommendation I might make is stiffer springs. Doing that this winter while in storage.
To suspension upgrade need help
