Exhaust rattle ?
Old Nov 15, 2015 | 11:34 AM
jakecol's Avatar
jakecol
Default Exhaust rattle ?
Stock 98 A4 having a rattle when in gear but not when in neutral/park. Sounds like it might be a baffle in 2 yr. old Flowmaster's. Is there baffle system in the cats?
Thanks for any/all input
Old Nov 15, 2015 | 12:44 PM
grantv's Avatar
grantv
Lower RPM can bring out rattles. Can you get it up on ramps and have someone hold it in drive while you check under?
All sorts of things could be rattling; front spring hangers, rear spring hangers, cats (internally many are like a small honeycomb and can come loose)...
Best to get under there either with a helper or rap on the exhaust with a rubber mallet or the palm of your hand.
Old Nov 15, 2015 | 01:01 PM
jakecol's Avatar
jakecol
Thanks for the ideas. I'll try all of your recommendations.
Old Nov 15, 2015 | 04:01 PM
grantv's Avatar
grantv
Palm of your hand... with leather gloves or when exhaust system is cool.
Old Nov 15, 2015 | 11:11 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
EXELLENT Recommendations.. Its called C5 BONDING!!! You will enjoy the expierence!
If your CAT rattles,, its BAD. If the muffler rattles, its bad too...
Please post up what you find
BC
Old Nov 16, 2015 | 06:33 AM
dadaroo's Avatar
dadaroo
Take a look at this, it might be your cause. Simple fix.
https://www.corvetteforum.com/forums...st-rattle.html
Mr. Sam
Old Nov 17, 2015 | 06:42 AM
ZigZag's Avatar
ZigZag
It very well could be your flowmasters. I had a rattle which I found by shaking each muffler and there it was so replaced them with new. I didn't know how old they were but it solved the problem. Shook them both when off and sounded like something broke loose inside alright.
To Exhaust rattle ?
