Headlight dropped down while driving.
Old Nov 20, 2015 | 04:27 AM
TraviZ06's Avatar
TraviZ06
Default Headlight dropped down while driving.
I turned on my headlights to leave work. I noticed my drivers light assembly was 'bouncing' and eventually it fell down. I got home and played with it. I can raise and lower the headlight without any resistance. I found an arm hanging off the motor that appears is supposed to attach under the headlight housing somewhere. Please see my pics.
The first two pics show the hanging arm, I see a hole like a bolt would go through it.
the last pic is of my passenger headlight, where that same arm goes. I can't see it myself. The best I could do was take a pic with my phone. Sorry for the blur. If anyone has insight what I am looking at, please elaborate what I need to do to correct this! Thanks!
Old Nov 20, 2015 | 11:38 AM
Road Runner's Avatar
Road Runner
St. Jude Contributor '03 & '04
You are missing the bolt that attaches to the arm. This happen to me many years ago and I was to far from service so I installed a threaded bolt with a lock nut. I've forgot about doing that until I saw this post. It's been 10 years.
Old Nov 20, 2015 | 01:43 PM
TraviZ06's Avatar
TraviZ06
So these bolts just back out over time? Lol. Is there any thing else this bolt hold in place? Is it a special design or can I get a generic bolt and nut like you did? Lastly, how do I most easily access this bolt?
Old Nov 20, 2015 | 05:01 PM
TraviZ06's Avatar
TraviZ06
I removed my headlight painted cover and was able to reach my arm down there. I found an aluminum pin that must be what wiggled out. I was able to press it back in through the arm. Was there anything to hold the pin on the other side? It didn't feel like it. It felt quite secure. I guess I will see how well it holds.
Old Nov 20, 2015 | 05:47 PM
LoneStarFRC's Avatar
LoneStarFRC
Default Push-on retainer
This is missing from your pivot pin:
http://daemar.com/wp-content/uploads...steners-01.jpg
Look for it laying in the bottom, or remove pin, drill hole and use cotter pin or hairpin clip.
http://htsmall.macsautoparts.com/***...u/64-14200.jpg
http://www.farmerboyag.com/images/28090015_l.jpg
Old Nov 20, 2015 | 05:59 PM
TraviZ06's Avatar
TraviZ06
Yes that's what I imagined would be on the end. I could not find it but I'll go purchase another one! Thanks!
Old Nov 20, 2015 | 06:25 PM
LoneStarFRC
If you want to eliminate the likelihood of it happening again, drill a hole and use either of the two types of retainers I mentioned.
That OE style push-on retainer is a crappy design.
To Headlight dropped down while driving.
