Wipers delay in "up" position, park correctly
So got a good new motor, works great and parks down, but when in intermittent delay mode they stop up instead of down.....could I have screwed up the wiper arm linkage? Took pics believe I got it right but hard to tell with the cam layers.
If any suggestions let me know, thanks in advance!
I can look to see what the FSM says but I rather doubt it is your installation if they Park in the normal wiper mode.
Mr. Sam
Also spoke to a ex-Ford tech he would suspect motor.
I'm just glad they work can live with it but stumped.
This one came with a swivel plate bit on the top of shaft but I took that off and used cam that was on the car assuming that's factory. The remanufactured Cardone I got that failed did not come with the swivel plate.
Sorry about the unclear 4th sentence, don't think it matters for this issue. What I meant was the the new motor came with a metal piece attached to the shaft where as the remanufactured and broke motor did not have this piece. Probably just a generic GM motor that needs the piece in some applications.
