cam swap question
Old Nov 22, 2015 | 01:43 PM
DannyBlake10's Avatar
DannyBlake10
Default cam swap question
ok for those of you have have changed out the cam in our cars.
I've got everything torn down. radiator out
water pump off
I'm down to the balancer and timing chain cover
my rack is in the way to pull the HB
am I better off removing the steering rack or unbolting the motor from its mounts and lifting it up a bit?
or is there another method for this?
thanks
Old Nov 22, 2015 | 01:48 PM
Uhhtaken's Avatar
Uhhtaken
From: Jacksonville,nc and Williamsburg,va North Carolina and virginia
I would just go ahead and move the steering rack out of the way. Its not too difficult and gives plenty of room to get the balancer off.
Old Nov 22, 2015 | 02:00 PM
DannyBlake10
ok
its just the two bolts and the tie rod ends from the spindles?
do I need to take the hoses off?
Old Nov 22, 2015 | 02:24 PM
Stroker87's Avatar
Stroker87
two bolts, steering shaft, tie rod ends and hoses
its not as hard as it sounds, just make sure to reconnect the hoses before you put every thing back in place (i learned the hard way) and refill the PS fluid then bleed it
good luck with that balancer though I broke 2 pulleys and spent about 4 hours before mine came off that was the WORST part of the whole job for me!
Old Nov 23, 2015 | 10:05 AM
DannyBlake10
damn, I was kinda hoping it would move enough out of the way without needing to pull the hoses
sounds good
thanks
my fun for the thanksgiving weekend!
Old Nov 23, 2015 | 06:06 PM
M_T_0's Avatar
M_T_0
replace the balancer while you are at it, the stock LS1 part is notorious for failing out of the blue, let alone after it is taken out and reinstalled.
and yes the hoses are a bitch to do after it is bolted up
Old Nov 23, 2015 | 08:30 PM
vettenuts's Avatar
vettenuts
Careful how to leave it while working. If the hose connections are pointing the wrong way you will lose all the fluid. I also replace the o-rings on the PS lines when I remove the rack. There is also a specific method for tightening the tie rod ends. If you move the tie rods as you move the rack, you can shift it to the passenger side and then down and right out of the car on the driver's side. Gives you a lot more room to work.
Old Nov 24, 2015 | 10:29 AM
Stroker87's Avatar
Stroker87
I left mine in the car just moved it to the passenger side (one car garage not enough room to slide it out all the way)
Old Nov 25, 2015 | 09:52 AM
DannyBlake10
its got an ATI super damper on it
but sounds good
should hopefully have my cam in this weekend and all put together minus my heads (waiting to get them back from porting)
Old Nov 25, 2015 | 11:47 AM
StingrayRebel's Avatar
StingrayRebel
I always do this, you can leave it in the car and move it all the way over to the passenger side then up at an angle to clear the timing cover... if you want to totally remove it you will have to lower the cradle in order for it to clear where the steering shaft and hose connections are at... you probably already know this but don't turn the steering wheel once you remove the steering shaft... you can easily damage some of the wiring inside the car if it turns too much, slightly side to side is ok but no more than 1/4 turn in my opinion... the first time I had my steering wheel locked down because I was paranoid but now that I am aware of it I don't do that anymore... the steering shaft will only go back on one way so no need to mark that
Old Nov 30, 2015 | 10:43 AM
DannyBlake10
yea the wheel is locked anyway and it wont unlock until the battery is reconnected so I couldn't move it if I wanted to, even with the key in
Great to know though.
saves me a lot of time no having to completely remove it
Thanks!
Old Nov 30, 2015 | 11:18 AM
Stroker87's Avatar
Stroker87
lot of guys like myself have the column lock bypass mod so yeah it is good to put it up for guy who need info
Old Nov 30, 2015 | 12:47 PM
Johnny wangwang's Avatar
Johnny wangwang
You don't have to drop or lower the cradle to pull the steering rack. Ive done it a few times without ever having to do either.
Old Nov 30, 2015 | 06:30 PM
Paul 75 L82's Avatar
Paul 75 L82
I pulled the rack but it was hard for me, not easy. Next time I might lower the cradle.
Old Dec 2, 2015 | 09:20 AM
DannyBlake10
yea looks like I can get it out with just moving the rack to the side
are there any other benefits of the column lock bypass other than being able to steer the car with the battery disconnected?
Old Dec 2, 2015 | 11:31 AM
Johnny wangwang
Yes. Being able to drive the car over 2mph and not being stranded when it goes bad!
Old Dec 3, 2015 | 11:43 AM
Stroker87's Avatar
Stroker87
as Johnny mentioned i very common for it to fail so doing the mod is just to avoid getting stuck when it does cheap and easy insurance
Old Dec 7, 2015 | 08:21 AM
DannyBlake10
huh, yea I think I'll look into that
Old Dec 7, 2015 | 01:49 PM
sean.b's Avatar
sean.b
looks like it was covered, but I went with the rack movement. Make sure it doesnt rotate, either, as it'll screw up the wheel position sensor, which isnt trivial to work with.
and yea, i drained all of my fluid. that car was down to curb weight when i was done. i made a mess!
dont forget to use heat on the pulley bolt. its not so bad if you heat it first.
To cam swap question
