Frame Saver Install - Welding
Old Aug 28, 2002 | 12:47 AM
Mark VerMurlen's Avatar
Mark VerMurlen
Default Frame Saver Install - Welding
I just received my front end frame saver kit (bracket and rollers) from A&A Corvettes. The instructions say to weld the bracket to the frame for extra strength. Are most people doing the welding or just using the bolts? If you haven't welded yours, are the bolts holding up or they getting bent?
- Mark
Old Aug 28, 2002 | 01:01 AM
Sales@MVPAutoParts.com's Avatar
0Sales@MVPAutoParts.com
Former Vendor
Default Re: Frame Saver Install - Welding (Mark VerMurlen)
Interested in finding this out also. :cheers:
Old Aug 28, 2002 | 01:39 AM
MRWHOOPPEE's Avatar
MRWHOOPPEE
Default Re: Frame Saver Install - Welding (Tuan Le)
I bolted them in then used my Mig welder.
Very happy with them :cheers:
After seeing them I'll make my own next vette :)
[Modified by MRWHOOPPEE, 5:13 PM 8/28/2002]
Old Aug 28, 2002 | 05:12 AM
FunDriver's Avatar
FunDriver
Veteran: Marine Corps
Default Re: Frame Saver Install - Welding (MRWHOOPPEE)
I had a shop install and weld them. The wheels are plastic so watch that you don't get the welder too close to them.
Old Aug 28, 2002 | 10:30 AM
Mark VerMurlen
Default Re: Frame Saver Install - Welding (FunDriver)
For those of you who had them welded in, did you repaint the frame and brackets black after welding to prevent rust? I would guess you also need to be careful to protect the painted facia of the car from heat and splattering during welding.
- Mark
Old Aug 28, 2002 | 01:06 PM
TeeJay's Avatar
TeeJay
I skipped the welding [about 2+ years ago] and checked a couple of times during the first few months - no problems. For what it's worth though, I haven't really "tested" the installation with a solid impact.
Old Aug 28, 2002 | 03:25 PM
Mad_Dog's Avatar
Mad_Dog
Cruise-In II Veteran
Cruise-In III Veteran
- Mark
Mark,
I mounted them, removed the rubber wheels leaving the bolt to hold the frame in place, had them welded at a muffler shop, and then remounted the wheels. The cost is nominal if all they have to do is weld.
These and the frame rails saved my car from major damage earlier this year during a spin out.
Old Aug 28, 2002 | 03:51 PM
Tracy's Avatar
Tracy
Default Re: Frame Saver Install - Welding (Mad_Dog)
I have used them *bolt-on only* on two cars, and both worked great. Never bent or loosened, etc etc. I guess if you have to mountain climb every day it might be good to weld 'em, but for occasional bumps and steep ramps, bolting works fine.
And by the way, I touch-up the bolt heads and nuts with a little dab of black paint and the 'Savers become invisible.
Old Aug 28, 2002 | 08:21 PM
FredC7's Avatar
FredC7
Default Re: Frame Saver Install - Welding (tracy)
I did not weld mine either and they have been fine. In fact, I'm glad that they were not welded or it would have been much harder to slip the facia off when I had to take it off recently to repair a sheared tab on one of the foglight surrounds. I have been "saved" several times and the wheel frames did not turn or move. Well worth the $$$. Thanks again Andy! :)
Old Aug 28, 2002 | 08:43 PM
KingTut's Avatar
KingTut
Default Re: Frame Saver Install - Welding (FredC5)
Mine are not welded and they hit almost every time I go in and out of my drive way. I have almost worn out the first set of wheels. I did however drill a second hole and I have two bolts holding each on. They are not going anywhere like that.
When I am ready to change the wheels out I may get them welded just for kicks.
Old Aug 28, 2002 | 09:00 PM
Racer's Avatar
St. Jude Donor '11
Default Re: Frame Saver Install - Welding (KingTut)
Mine are not welded and have been used a whole bunch, being lowered 2"! They are in perfect shape. By not welding, it leaves me so many options to remove or replace or put back to stock when I trade it in, so I can use them on the next one. :cheers:
Old Aug 28, 2002 | 10:30 PM
see5's Avatar
see5
Bolted and welded here. Had them bolted then did X pipe and then less than a minute were welded.
To Frame Saver Install - Welding
