Air Conditioner Problem
When the AC is ON, does the LARGER metal line under the hood & the receiver dryer get very cold?
When the AC button is first pressed, does the Compressor Clutch energize and the belt drive hub connects to the compressor drive hub (through the electric clutch)?
IF,,,,,,,,,,,,,,,,,,,,,,,,,, you think that its LOW on charge, you really need to put a set of gages on the system to monitor the High and Low pressure sides of the system. Each pressure is a product of outside temp, humidity, fan speed and engine RPM.
Bill
Most common issues are
1. If your car has LT headers--then you must alter the A/C pressure line by bending it away from touching or being very close to your headers tubes on the pass side---Having the pressure line too close to the headers will not allow the A/C to throw cold air
2. Early C5's are known to have the HVAC displays to go out and fail--The lights on the dash for the heater --A/C and defrost go very dim and consequently won't work-- You can have them repaired for about $150 --Find where on the forum--
