Shift Issue
Old Dec 3, 2015 | 02:03 PM
clyons's Avatar
clyons
Default Shift Issue
A friend of mine recently purchased a 2004 C5 with an automatic transmission. He ask me to drive it aggressively to see how it would perform. After finding a suitable spot I turned off the traction control. I put the shifter in low and nailed it. It felt like it took off in second for just a couple seconds then shifted down in low. Anyone have any thoughts on what would cause this or what I should check? Thanks
Old Dec 3, 2015 | 02:23 PM
dadaroo's Avatar
dadaroo
Old Dec 3, 2015 | 03:03 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I agree on the need to read the DTCs AND I also strongly recommend that you OBSERVE the IPC "DIC" display for messages I.E. Traction Control ACTIVE or any other message.
Bill
Old Dec 3, 2015 | 10:27 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
You must come to a complete stop on an auto trans in order for it to drop into 1st--- No rolling stops !!!!!
No need to put it low--just leave it in drive----
The only reason other than that that would cause an auto trans to start off in 2nd gear or to be locked into 2nd gear is if the car was somehow in the "reduced power mode or limp mode"--- Many things can cause a limp mode--but normally you will get an accompanying DTC code---
Rarely you can have your trans selector switch on the trans case that is broken or out of adjustment so it won't drop into 1st manually--but it should always drop into 1st while in "D"-----
Old Dec 4, 2015 | 09:45 AM
pmr2000's Avatar
pmr2000
I'm new to a slushbox after 30 years of sticks....I find that leaving it in drive the auto shifts pretty aggressively stock. Feels like a bat out of hell in first and second. I tried to take off in low then shift could not get it to move any faster than in drive.
But definitely want to ensure the auto shifts through all the gears manually and in drive o.k..
Old Dec 11, 2015 | 02:22 AM
tblu92's Avatar
tblu92
My experience says the same thing---no advantage by manual shifting a C5 auto---You can't shift the trans any quicker or more consistent than the computer will---The "shift times" don't change in the tune when manual shifting or auto shifting on a C5
PS: some say that while drag racing it is better to leave the trans in 3rd rather than drive--The explanation I was given was that the shifts aren't any quicker but one more band is engaged to make the clutch pack stronger and makes your trans more robust----Haven't been able to confirm this but maybe a trans guy can chime in---
Old Dec 12, 2015 | 06:12 PM
drtyTshrt's Avatar
drtyTshrt
Hijack
I replaced my A4 shifter cable today and now noticed that I can shift into neutral from OD without pushing the button.
Is this normal?
Old Dec 12, 2015 | 09:16 PM
tblu92's Avatar
tblu92
Originally Posted by drtyTshrt
Hijack
Is this normal?
YES-- Normal--The button is a safety thing that prevents you from accidently shifting into Reverse OR Park while manual up shifting--
Old Dec 13, 2015 | 12:25 AM
RonSSNova's Avatar
RonSSNova
It's pretty hard to manually shift the A4. 1-2 is fine, but if you try to do the 2-3 at a mph higher than the programming calls for, it will just say "FU" and hit the rev limiter.
So if trying it, do your 1-2 shift, then put it in 3 right away and it will do the 2-3 shift for you.
But as was said, might as well just let it do them all for you.
To Shift Issue
