DIC Backlights Always On - Draining Battery
Old Dec 14, 2015 | 09:06 PM
kmetros's Avatar
kmetros
Default DIC Backlights Always On - Draining Battery
All,
I'm having a problem that several others have identified here on the board with my DIC backlights not turning off and draining the battery. Below is a thread that I found that shows two fixes - a wiring fix and a fix to the IPC, which controls these lights being turned off.
The wiring solution is found in post 43 in the link below. My question is, does anyone know how much the wiring varied over the years for the DIC? I'm not an electrical person as far as chasing down wires, but I am capable of doing the procedure in post 43 provided the wires are the same.
I have a 99 FRC non HUD model with just the DIC buttons on the right and the dimmer **** on the left.
The IPC fix is outlined in post 46. Where is the IPC physically located. Is it something I can buy, take to the dealer, have them program the mileage and be done with it? Do I tell who I bought it from the mileage on the car and install it myself? Any thoughts.
https://www.corvetteforum.com/forums...ways-on-3.html
Finally, I checked under the passenger floor board and have no signs of water or moisture.
Any updates to a fix since these were posted a while ago? I'm getting tired of unhooking my battery!
Kurt
Old Dec 14, 2015 | 10:04 PM
kmetros's Avatar
kmetros
Originally Posted by 8VETTE7
IPC = Instrument Panel Cluster
Go to post #15 at the link below for a link to a company that may be able to fix your problem:
https://www.corvetteforum.com/forums...post1585780347
Thanks for the response! So, the IPC is the whole instrument cluster, which gets pulled and sent in. Nice. Can you still drive the car (will it run) without the instrument cluster?
Kurt "gauges, I don't need to stinkin' gauges" Metros
Old Dec 15, 2015 | 07:50 PM
kmetros's Avatar
kmetros
I got luck on this one. When I opened the BCM cover there was a purple wire that had been spliced into that was squished between the BCM case and the cover. When I bought the car an aftermarket stereo had been pulled and the stock one reinstalled, so I just figured this was leftover wiring from then. I moved it out of the way before replacing the cover after confirming there was no moisture. Today I noticed that the lights go off as they should. I can only assume that the wire I moved or something close to it was my culprit. I'll have to watch the lights for a while, but my gremlin seems to be gone for now.
On a side note I had contacted Nationwide Instrument Cluster as others have suggested and was told by them that they parts they need to make that repair are no longer available and they can't provide the service any longer. Bummer.
Kurt
Old Dec 15, 2015 | 09:45 PM
kmetros's Avatar
kmetros
Good thing to know. That pretty much means a used IPC is the only solution.......
Right. Add it to the list. Plus I understand the mileage is stored on the IPC so I'm not sure how you would resolve that when installing a used unit?
Old Dec 15, 2015 | 10:23 PM
kmetros's Avatar
kmetros
Mileage CAN be reprogrammed on the IPC to match that of the receiving vehicle.
Good to know. What does that take to reprogram the mileage? Is it a stealership proposition or can it be done some other way?
Kurt
Old Dec 16, 2015 | 05:15 AM
dadaroo's Avatar
dadaroo
Some dealerships can do it but most (if not all) Speedo shops for newer cars should be able to do it.
To DIC Backlights Always On - Draining Battery
