Romulus Engine Assembly
Old Aug 28, 2002 | 10:56 PM
bundy's Avatar
bundy
2nd Gear
Default Romulus Engine Assembly
Hi Everyone,
I am new to the Corvette Forum, and I am not sure if this is the appropriate section for this topic, but here it goes. I am from Hamilton, Ontario, Canada and I have recently purchased my first Corvette - a fully loaded, stock 1997 Torch Red MN6.
I found the matching VIN derivative stamped on the engine block, and while I was changing the oil, I noticed a label attached at the front of the driver side of the cylinder case. It had the following info:
ZYC (engine suffix for a 1997 6 speed)
IIIIIIIIII (this is my poor representation of a barcode)
212 040697 08:31:01
Now, I know the order for the vehicle was entered into the Bowling Green computer on April 7, 1997 and the build date of the car was April 21, 1997.
I was assuming, therefore, that the label on my motor corresponds to an engine assembly date given the presence of an engine suffix code. Basically, I thought that the 040697 08:31:01 portion meant that the engine was assembled at the Romulus, Michigan plant on April 6, 1997 at roughly 8:30 am. If correct, this would peg the engine assembly at two weeks before vehicle assembly. I am fine with that.
HOWEVER, if I am correct in the latter assumption re:the date, April 6, 1997 fell on a Sunday!!!!! Is it possible that in April 1997 the Romulus Powertrain Plant was turning out LS1 engines for the 'Vette? Was there shifts on Sundays? Or overtime on Sundays?
I hope someone can help.
Old Aug 28, 2002 | 11:29 PM
adityaax's Avatar
adityaax
Default Re: Romulus Engine Assembly (bundy)
I thought all Vette engines (LS1/LS6) are built at St. Catherines engine plant?
Old Aug 28, 2002 | 11:53 PM
bundy's Avatar
bundy
2nd Gear
Default Re: Romulus Engine Assembly (adityaax)
Actually, engine production moved to St. Catharines beginning some time during the 2000 production year. Romulus, Michigan was the source for engines for 1997-1999 and most of 2000. (Taken from the 1953-2002 version of Corvette Black Book.)
To Romulus Engine Assembly
