Leak Passenger Foot Well
Old Dec 18, 2015 | 06:11 PM
CharlieC5Z06's Avatar
CharlieC5Z06
Default Leak Passenger Foot Well
Hello I asked about leaks and my car not starting a couple weeks ago. I got my car working again because water was leaking onto the Anti Theft relay in the passenger foot well.
Below is a quote from my last post on my other thread, any ideas where it can be leaking from?
So I cleaned out all of the udders in the car and only 1 was actually clogged the rest were fine. I had the shop that changed my oil the other day check that tube behind the battery when they had it on the lift and they said it was clear.
I did a manual car wash last week and it didnt leak.
So I was hoping it was that one udder that was clogged and took it for a car wash today and kept the floor panel off so I can see if it was leaking and it did. It was dripping down from right above the relay that got damaged before.
When I pulled out of the car wash I can hear water swishing all around from somewhere. Then I parked in the garage and water was pouring out from under the car on the front pass side right by the front passenger wheel. I have no idea where this leak is coming from. Any help will be great, thanks.
https://www.corvetteforum.com/forums...ting-help.html
Old Dec 22, 2015 | 02:44 PM
johnson-rod's Avatar
johnson-rod
Remove your car from the car wash and don't put it back in there again.
There is a tag that hangs down underneath the car with washing instructions. It may have been removed by one of the previous owners. It clearly states that these cars are only to be hand washed and hand dried immediately. It is illegal to remove this tag.
Oh, the humanity...
