loose windows
Old Dec 26, 2015 | 11:16 PM
HeavyC's Avatar
HeavyC
5th Gear
Default loose windows
When my door is open there is a lot of play in my door windows. What parts are wore out and how do I fix it....... Drivers door window is super loose and has deep scratches. Thanks in advance.
Old Dec 27, 2015 | 01:35 AM
Bubbletop409's Avatar
Bubbletop409
The regulators are either loose, worn, or broken. Do a search, found a source and a video to do mine, much easier than I had anticipated.
Old Dec 27, 2015 | 09:46 AM
dadaroo's Avatar
dadaroo
See if this helps any for getting into the door and working on the regulator.
http://www.vetteessentials.com/instr...or_handle.html
Mr. Sam
Old Dec 27, 2015 | 01:10 PM
CactusCat's Avatar
CactusCat
I'm going to watch this one. I have this same issue, loose windows, especially on the driver side. However, I have no scratches and both windows work perfectly. They just feel loose when the door is open and when I'm driving with the drivers's window down, I can hear it rattling inside the door. Might be a nice winter task for me.
Old Dec 27, 2015 | 01:59 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
at the bottom of the door (inside the door)the window regulator support sits in a grommet and it works it way up the support so the regulator doesn't sit tight !!!
Old Dec 27, 2015 | 02:00 PM
HeavyC's Avatar
HeavyC
5th Gear
Thanks Dadaroo! Wasn"t sure if regulator was loose or if there was some plastic rollers that break.
Old Sep 13, 2020 | 04:57 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
Default back to the basics
Check all the regulator adjustment points to ensure they are tight.
To loose windows
