Question on brake
Old Dec 30, 2015 | 04:56 PM
DA1984VETTE's Avatar
DA1984VETTE
Default Question on brake
I am planning on having my calipers powdercoated and have a question for you guys that have done this. I have done a search and haven't come up with any info. When removing the calipers from the brake lines how did you keep them from leaking brake fluid and getting air in the lines. When I did the ones on my 84 I painted and reinstalled the same day, but I let the lines open and kept the brake fluid reservoir full. But since this is going to be a few days wondering what was the best way to keep the lines from leaking and draining my fluid. Also plan on putting steel lines on as well. Any help would be appreciated.
I guess I didn't include that the calipers would be gone for a couple of days or so. So, with that being said how do I now keep the fluid from leaking out of the lines? Sorry for the wording...
Old Dec 30, 2015 | 05:01 PM
zachaeous's Avatar
zachaeous
I did my calipers when I rebuilt the motor in May of this year and I just caught the fluid in drain pans and then reinstalled the calipers and hooked up the lines and bled the brakes just like any other car. They came out just fine and I did not have to have the tech 2 to bleed them. 5000 miles since and no problems with the brakes. Good luck
Old Dec 30, 2015 | 09:00 PM
DA1984VETTE
Added to original post, but thanks for your response zachaeous.
Old Dec 30, 2015 | 09:23 PM
zachaeous's Avatar
zachaeous
p
My calipers were gone for over 2 weeks and I did not have any problem bleeding the system
I did not lose that much brake fluid when I did mine. You could get some plastic caps and put on the fittings where the flex lines hook to the steel lines.
Old Dec 31, 2015 | 10:35 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Go to Staples or some place that sells office goods and pick up some of those large clips that you squeeze and they secure large stacks of paper together.
Find some thin rubber sheet or cut up some plastic like is used on a butter tub top into pieces big enough to cover the hole on the fitting that bolts to the caliper (both sides). Use the clip to hold the plastic/rubber on the fitting.
That should be enough seal to get you by until you can reinstall the calipers
NOTE/WARNING/CAUTION:
When you reinstall the calipers,,,,, MAKE SURE that you install them on the proper sides of the car. If you don't, the brake bleeder fitting will be on the BOTTOM of the caliper and you will NOT be able to properly bleed the air out of the caliper!
Make sure that you properly service the caliper sliding pins. Purchase the correct synthetic caliper pin grease. Using the incorrect grease will result in calipers that stick and damage the pads. I use the Permatex Ultra Disc Brake Caliper Lube:
http://www.permatex.com/products-2/p...er-lube-detail
Old Dec 31, 2015 | 01:10 PM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
I actually just did this to my car (removed the stock brakes) and though I'm replacing the lines, I didn't want the fluid to go everywhere and drain while I was taking my time. I used a silicone plug in each banjo bolt and haven't lost a drop of fluid yet. Been sitting that way for about four weeks now.
Old Dec 31, 2015 | 01:47 PM
Patches's Avatar
Patches
I plugged my lines with rubber caps at the time to minimize leakage and getting brake fluid on the floor or car. It's really a moot point about bleeding after the reinstallation - you should absolutely bleed the brakes after disconnecting the lines from the calipers to be safe. Inevitably, a little air gets in the system when you disconnect lines from calipers. Just make sure you install the bleeder plugs facing up when you put the calipers back on the car. Use a Tech2 to bleed the entire system if you have access to one - this is the perfect time to get a new brake fluid charge in.
Old Dec 31, 2015 | 02:44 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I AGREE 100% ALWAYS 100% renew the system fluid when the system is down this far!!
. In fact, I would do the system bleed with the new fluid before you pull the system apart. That way you will have all new fresh brake fluid and NO air in the system once its back together.
To Question on brake
