Is 10W40 going to harm my engine?
Old Jan 5, 2016 | 04:53 PM
mikex7's Avatar
mikex7
Default Is 10W40 going to harm my engine?
So I just had some work done to my car and I told the mechanic to swap out the old oil with 5W30 like I have for years. I went to pick up the car and he told me he put 10W40 because he likes it better for these cars with higher miles (im at 155k).
I wasn't very happy with him making that call when I specifically asked for 5-30. Just wondering if I should drain the 10-40 or if it should be OK for a few thousand miles.
I live in Southern California so the weather is pretty mild if that matters for the viscosity.
Old Jan 5, 2016 | 05:18 PM
feeder82's Avatar
feeder82
It will be fine no worries
Old Jan 5, 2016 | 05:26 PM
GUSTO14's Avatar
GUSTO14
Did he use synthetic (10W-40) or conventional oil? In this case, that is much more important than the viscosity. If he used synthetic I would leave it alone until the oil-life-monitor calls for another change. If it's conventional, 3-5k max.
Good luck... GUSTO
Old Jan 5, 2016 | 06:20 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
I go by what is on the oil cap !!!! Mobil One 5w30 !!!!
Old Jan 5, 2016 | 07:44 PM
mikex7's Avatar
mikex7
Good luck... GUSTO
Thanks. It's Castrol Edge Synthetic. I've used Mobile 1 5-30 synthetic for the 9 years I've had the car.
Old Jan 5, 2016 | 08:14 PM
If it is full synthetic oil, you'll be fine, but if you really like that shop, I would make it clear to him that in the future he is not to change your directions unless he clears it with you first. It's not his final decision on what happens to your car, it is yours. He should only make recommendations and await your approval.
Old Jan 5, 2016 | 09:04 PM
73Corvette's Avatar
73Corvette
Old Jan 5, 2016 | 10:06 PM
Michael A's Avatar
Michael A
If you lived in the snow belt, I would probably change it out, but since you are in Santa Rosa, I wouldn't bother.
Michael
Old Jan 6, 2016 | 12:30 AM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
I agree I would question any shop that would suggest an oil viscosity other than stock recommended--especially without your permission---This is wintertime so I would want thinner oil in my engine --especially if you live in a cold snowy area----
I would leave it in for awhile but change back to the factory recc viscosity-- as soon as 2000 miles
On some of these new cars with AFM it is imperative to use the recc oil----as the AFM system is highly dependent on oil viscosity and pressure--
Thicker oil creating more oil pressure and flow is an old school wive's tale and not relevant on today's modern engines
Old Jan 6, 2016 | 01:24 AM
LoneStarFRC's Avatar
LoneStarFRC
You'll be fine.
HOWEVER, I would make it clear that your next oil change is on them. If they don't like it, find someone who WILL follow your directive.
Old Jan 6, 2016 | 10:42 AM
jackthelad's Avatar
jackthelad
I would take it back and tell them to put in what you asked for.
(a) the manual says 5-30, and (b) that's what you asked for.
They should have asked you first before they went against your instructions.
Many people like the Mobil 1 5-30 high mileage, as the additive package is pretty much the same as the M1 spec was when the factory selected it.
Going to 10-40 won't break anything, but to me it would be a matter of principle.
Old Jan 6, 2016 | 10:51 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
LOL! Don't lose any sleep or get grey hair over the issue.
Like was previously stated, If you were in an area where the temps were in the 10-20 deg range, I MIGHT be a little more concerned.
When its time to change the oil, just go back to the 5-30..
Old Jan 6, 2016 | 03:10 PM
wcsinx's Avatar
wcsinx
I've used Castrol Edge Syn 10w-40 several times now (my choice of oil largely depends on what's on sale and/or offering rebates at the time). It's perfectly fine oil for any LS engine. I do live in Central FL, but even in colder climates, the difference between 5 and 10 weight will hardly make a difference.
As has been mentioned, what matters most is the fact that it's synthetic. C5s really need the synthetic as they tend to run hotter than other LS engine'd vehicles. I've noticed my car consumes about 2x the amount of conventional oil as synthetic.
Old Jan 7, 2016 | 12:29 AM
onspeed's Avatar
onspeed
So that's why the AFM isn't working on my C5.
Old Jan 7, 2016 | 12:57 AM
jim993's Avatar
jim993
That oil will be fine.
I have been running Red Line 10W40 since I started tracking the car five years and 25,000 miles ago.
Mobil 1, through their oil expert, made it clear some time ago when Mobil 1 recommended that Corvette owners who track their cars drain out the Mobil 1, 5W30 and replace it with Mobil 1, 15W50.
A primary reason that auto manufacturers have gone to thinner multi viscosity oils over the last 20 years is to help them achieve their required corporate average fuel economy (CAFE).
Old Jan 7, 2016 | 01:36 AM
tblu92's Avatar
tblu92
Funny guy---" some of these new cars" Yes on Silverado's with AFM GM has had many lifter failures that will take out and destroy the whole engine----AFM is very clean oil--correct viscosity and pressure sensitive---As a matter of fact in 2016 because of so many failures GM has re-designed the entire lifter shut off process in them---as well as the AFM lubrication process----That being said even on older LS's I would never alter from the recc oil viscosity---Typically LS oil pumps are hi pressure low volume designs---Using thicker oil changes the lubrication characteristics of the oil system---
C7 Corvettes and all DI engines have changed now to a high volume and low pressure oil pump--- C7 tops out at only 40-45 PSI at WOT----Radically different than older LS1 and LS2 engines----
Engineers have spent months on lubrication and I don't think anyone other than them would have the best insight on what is correct for a particular application---
Old Jan 7, 2016 | 04:01 AM
rustyguns's Avatar
rustyguns
Bill knows his stuff! You guys would have a heart attack if you knew i ran 20-50 in the winter lol Does anyone even know what the numbers mean? i have been on and seen so many oil threads, it is just hilarious how ignorant everyone is on oil LOl
If you don't bounce it off the rev limiter every time you shift, you can damn near run anything, these motors are tough as hell! fricken amazing engines! Fyi i have owned 5 of these puppies, raced all of them and owned over 80 vehicles been wrenching for 45 years
To Is 10W40 going to harm my engine?
Old Jan 7, 2016 | 07:58 PM
TrackAire's Avatar
TrackAire
The SRT guys also suggest this when tracking the Viper....Since oil is not compressible, theoretically you could run 0W20 oil and it would keep the moving parts from touching each other. What I really think is going on with the recommendation regarding the 15W50 oil is less oil aeration at sustained high rpm's. The number one thing you don't want is air bubbles in your oil because it then becomes compressible. Once that occurs, bad things happen inside your motor.
Old Jan 7, 2016 | 09:35 PM
NXS's Avatar
NXS
Your oil will be fine
As a motor gets more miles bearing clearances increase as well as any other moving parts (piston to wall, the lifters internal piston, valve guide etc)
The higher the number the more viscous (thicker) the oil is. It flows out of these clearanced areas slower, possibly closer to the flow rates when the engine was new.
The suggested 5-30 is for standard driving conditions to achieve good fuel mileage when new.
What's important is the oil pressure. If the thicker oil exceeds the factory pressure it *may be an issue but this is highly unlikely.
What is more likely is the oil your mechanic installed probably brought your oil pressure closer to factory spec.
Old Jan 7, 2016 | 10:34 PM
Chris Stewart's Avatar
Chris Stewart
It's totaled. Time for a new vette.
