memory seat issue....
Old Jan 10, 2016 | 01:13 PM
ZeeOh6vette's Avatar
ZeeOh6vette
Default memory seat issue....
Hi I got in my c5 z06 to go to work this morning and noticed the easy entry and exit was not working I tried resetting it and the memory light just steady blinks it was around 30degrees in my garage so I thought maybe it had to do with it being cold but when I warmed the car up it still has consisted so I am wondering if anybody has any experience with this? Also my mirrors and heat are working correctly just not my seat functions all though my seat works fine manually if I adjust myself another words no memory functions with seat all other memory is fine.
Old Jan 10, 2016 | 05:45 PM
CamminC5's Avatar
CamminC5
St. Jude Donor '15-'16-'17-'18
Any SCM (seat control module) codes?
Old Jan 10, 2016 | 06:47 PM
ZeeOh6vette
No codes on the dash if that's what you are asking
Old Jan 10, 2016 | 08:24 PM
CamminC5's Avatar
CamminC5
Did you go through the sequence to pull the codes or are you just saying nothing has come up? (not trying to be a smart *** just want to be clear).
Old Jan 10, 2016 | 09:00 PM
ZeeOh6vette
No I know your not its my first vette I don't know how or even heard of a sequence I was just stating there wasn't anything popping up on the dash but the memory button keeps blinking when I press it or when I turn the ignition off and on and when I shut off the car the security light kept blinking
Old Jan 10, 2016 | 10:39 PM
GUSTO14's Avatar
GUSTO14
Verify the battery voltage before starting the car and again after the car is running and post both values here.
Pull and post the codes. If you have never done this here is how:
OR
http://www.c5forum.com/ayc/dtcdic.php
Post ALL the codes and the H or C or HC that follow each 5 character code.
Good luck... GUSTO
Old Jan 10, 2016 | 10:53 PM
ZeeOh6vette
[QUOTE=GUSTO14;1591295353]Verify the battery voltage before starting the car and again after the car is running and post both values here.
OR
Thank you! Post the codes here on this thread? I can get to it tomorrow night.
Old Jan 10, 2016 | 11:11 PM
GUSTO14's Avatar
GUSTO14
Yes. That info will enable folks here to provide more specific guidance verses just taking shots in the dark.
Good luck... GUSTO
Old Jan 23, 2016 | 01:46 PM
ZeeOh6vette
The codes I pulled are all 6 ao ldcm
B 2285h
2284h
U 1255h
1064h
1016h
1096h
Second set a1 rdcm all 6 also
B 2283h
2285h
U 1255h
1064h
1016h
1096h
Please lmk what these mean?
Old Jan 25, 2016 | 10:52 PM
ZeeOh6vette
Bump
Old Jan 26, 2016 | 03:13 PM
CaseyJones's Avatar
CaseyJones
Either the connector in the accordion seal between the door and the body is corroded or not making good contact. Also, I was getting LDCM (Left Door Control Module) codes like that and it turned out to be the memory module under the seat is probably going bad. All that stuff is so interconnected that it can be hard to troubleshoot from a distance.
Old Jan 27, 2016 | 12:28 PM
tgucc's Avatar
tgucc
First, seat memory only works after you've pressed the fob and gotten into your car. Took me a while to figure that out.
I was having the intermitting issues too and pulled codes. Do a search on the seat or memory control module. I pulled the drivers seat out, cleaned the contacts on the connector under the seat and also did the seat controller fix. There are threads on the fix but what it involves is taking apart the seat control module under the drivers seat and re-soldering some of the circuit board contacts. It wasn't too bad but fixed the problem.
To memory seat issue....
