Lifters
Old Jan 11, 2016 | 01:28 PM
HERK's Avatar
HERK
Default Lifters
Would anyone have an idea on how much it would cost to replace lifters on an 03 LS 1 ? In Florida. Thanks guys.
Old Jan 11, 2016 | 01:33 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Don't know how much but you have to go THIS FAR to get to them:
WHY do you think you need LIFTERS?
BC
Old Jan 11, 2016 | 01:36 PM
HERK's Avatar
HERK
Very loud knock when cold. Gets much less when it reaches temp. 105,000 miles.
Old Jan 11, 2016 | 02:11 PM
VJD2's Avatar
VJD2
St. Jude Donor '11
More likely piston slap then lifters.
Old Jan 11, 2016 | 07:41 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Its either piston slap or a connecting rod with excessive clarance. If you purchase a mechanics stephescope and put the rod on the valve cover (over top over each valve rocker),,, you can hear EACH ROCKER and its associated components. If its one of them, it will stand out like a sore thumb
If its a Con rod or piston slap, put the rod down near the oil pan (Between the pan and the spark plug) and the sound will be amplified the closer you get to it.
Before you go into pulling the heads,, give that simple test a go and see where you stand..
You can get four or five feet of 5/16 vacuum hose and do the samething. Put a small screw into one end and the other end in your ear. Place that screw end on (say a fuel injector) and listen to it to give you an idea how it works. Reve the engine and you can hear the firing frequency in the injector change..
If you just point the OPEN end of the hose at an area, it will guide you right to the noise area. You will be surprised at what you can hear with just a piece of vacuum hose.
Bill
Old Jan 11, 2016 | 11:26 PM
HERK's Avatar
HERK
Thanks very much guys. I see that you are all from CT. My daughter is in Bethel.
Old Jan 13, 2016 | 11:25 AM
Ray 2000 C5 FRC's Avatar
Ray 2000 C5 FRC
Bill
Another trick to identify which cylinder may be bad is to pull the spark plug wire or connector to the coil pack one at a time, if you hear no difference, reconnect the wire and go to the next cylinder. What this does it stops that one cylinder from firing, and the bearing will not experience any force from the piston being fired.
Old Jan 13, 2016 | 12:57 PM
HERK's Avatar
HERK
Thank you Ray. I'll try that.
Old Jan 14, 2016 | 07:29 PM
VJD2's Avatar
VJD2
St. Jude Donor '11
Bethel is nice, had friends that lived there.
Good Luck with your issue!
Old Jan 14, 2016 | 08:35 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Might be bad rocker bearings. I understand that they are notorious for spitting out the rollers from the fulcrum point.
Old Jan 15, 2016 | 01:07 AM
S.C. vette's Avatar
S.C. vette
Veteran: Marine Corps
Keep us updated as to you find...
To Lifters
