first motor build and i need help...
Old Jan 11, 2016 | 10:33 PM
luc719's Avatar
luc719
Default first motor build and i need help...
What's going on guys, I am doing my first motor build and kind of messed up a little bit. I was installing a new camshaft from comp, and after I got it in I realized there was no dowel pin in the end of the cam for the timing gear.
So my question is what should I do from here? Can I knock the pin in while the cam is in the block or should I take it out?
thanks
Anthony
Old Jan 11, 2016 | 11:30 PM
tommypenguin's Avatar
tommypenguin
I would not not drive the cam with a hammer or anything else with the cam in the block it could damage the journals on the cam or the cam bearings. You sure you didn't install it backwards and the dowel isn't on the other side?
Old Jan 11, 2016 | 11:52 PM
VGLNTE1's Avatar
VGLNTE1
St. Jude Donor '14-'15
Just take it out. Takes 15 seconds
Old Jan 12, 2016 | 12:28 AM
tommypenguin
If you haven't done so don't forget to lather the cam in assembly lube.
Old Jan 12, 2016 | 07:33 AM
7LitreC5's Avatar
7LitreC5
I'd take it out. I wouldn't want to risk damaging anything.
Old Jan 12, 2016 | 03:25 PM
CamminC5's Avatar
CamminC5
St. Jude Donor '15-'16-'17-'18
When in doubt pull it out.
I kind of think it's in there backwards too.
Old Jan 12, 2016 | 03:39 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
There's a WELSH plug at the other end of the cam.. If you strike it, it will POP OUT!
Old Jan 12, 2016 | 10:44 PM
RonSSNova's Avatar
RonSSNova
The rear cover is at the other end. There is no plug like the old small block.
Old Jan 12, 2016 | 11:46 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
To first motor build and i need help...
