Digital/Analog Oil Temp mismatch
Old Jan 14, 2016 | 02:56 PM
nightman06's Avatar
nightman06
Default Digital/Analog Oil Temp mismatch
So I noticed today that my oil temp is rising a heck of a lot faster on my analog gauge than on my DIC.
If I turn the car on in the morning (48 degs outside) and allow it to idle for 15 mins my analog gauge comes off the peg to read ~130 but my DIC reads just above ambient ~60. After about 15 mins of easy driving my analog will come up to near operating temp ~170 and my DIC reads ~115. Eventually they will match once the DIC catches up and both seem to be accurate once they do, but what causes this? Im assuming the DIC is more accurate given the "rapid" warm up time indicated by the gauge?
Some notes, the vehicle is TT running an oil cooler with 180 deg thermostatic bypass, and the PCM is swapped with an '03. Car is a '97. No codes.
Old Jan 14, 2016 | 04:15 PM
nightman06's Avatar
nightman06
TTT, thoughts??
Old Jan 14, 2016 | 04:18 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
didn't know we had oil temp on the gauge panel?????
Old Jan 14, 2016 | 04:45 PM
LoneStarFRC's Avatar
LoneStarFRC
Originally Posted by nightman06
TTT, thoughts??
I would chalk it up to the likelihood of a calibration discrepancy between the two sensors and/or the two different "gauge" readouts.
Old Jan 14, 2016 | 04:46 PM
nightman06's Avatar
nightman06
This isn't for the cluster (coolant gauge) this is for a separate oil temp gauge that I've got installed. I should've clarified. Im sure this is simply an issue of the aftermarket gauge sensitivity.
Old Jan 14, 2016 | 04:55 PM
LoneStarFRC
Old Jan 14, 2016 | 04:57 PM
LoneStarFRC
As I said, I think it's very likely the difference in sensor quality and/or accuracy between the two.
Old Jan 14, 2016 | 04:59 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Originally Posted by LoneStarFRC
I guess I consider that digital and the dash gauges analog ????
Old Jan 14, 2016 | 05:06 PM
LoneStarFRC
I would agree with you but that's not what he said. He has an analog gauge and he is comparing it to his DIC readout.
Note: He says he has a twin turbo car. It's not surprising he would have a number of analog gauges. Very common.
Old Jan 14, 2016 | 05:10 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
my bad !!!!!
Old Jan 14, 2016 | 05:23 PM
LoneStarFRC
my bad !!!!!
IAG!
Old Jan 14, 2016 | 08:56 PM
CaliforniaJack's Avatar
CaliforniaJack
Default practical science
If you're really interested, do what we did back in engineering school and put both sensors in the same glass of water and turn on the heat. Then each minute record both readings. When the water boils, see which gauge reads 212 (at sea level) first. If they both track at the same rate, it means that the installed slower sensor is not exposed to the same fluid stream as the other.
Old Jan 15, 2016 | 11:10 AM
Gordy M's Avatar
Gordy M
Part of the problem you are experiencing is the refresh rate of the PCM for the oil pressure PID. Until you reach operating temperature, the DIC should lag a well calibrated analog guage. When I autocross or HPDE, I only have the oil temp showing on the DIC and when I am in the pits you will see the guage refresh about every 2-3 seconds when idling and the fan on high.
Old Jan 15, 2016 | 11:29 AM
aaronc7's Avatar
aaronc7
Where do you have the probe installed for the analog gauge?
Old Jan 18, 2016 | 09:48 AM
Gordy M's Avatar
Gordy M
You can replace your oil pressure sensor location to the oil pan. GM makes a part to attach above the oil filter (replaces the block off plate) and then re route to the gauge and then to the OPS. I might have some pics at my home computer, if I can find them I will post them.
Old Jan 18, 2016 | 10:10 AM
CamminC5's Avatar
CamminC5
St. Jude Donor '15-'16-'17-'18
That's what I was thinking. If the factory sensor is still down at the oil filter and he's using an adapter at the oil filter for the cooler this could be the reason for the change.
Is this the case OP?
Old Jan 18, 2016 | 01:31 PM
Gordy M's Avatar
Gordy M
No, it is the refresh rate the PCM sends information to the cluster and OBD II. If you have access to a good scan tool you can see the changes to Oil temp, rpm, water temp, etc on the scanner as it is refreshed. GM has designated certain PID's (parameter identification) to refresh at different intervals. An example the the Oxygen Sensor may refresh at up to 40 cycles per second, the engine voltage may refresh at 1 cycle/second and the oil temp may refresh at 0.5 cycle/second. Thus every two seconds the oil temp will change until it reaches an equilibrium temp.
Old Jan 18, 2016 | 01:47 PM
CamminC5's Avatar
CamminC5
Didn't know that. Thanks for the explanation.
Old Jan 18, 2016 | 09:32 PM
aaronc7's Avatar
aaronc7
I get that oil temp on the DIC might have a somewhat slow refresh rate... you say updates once every 2 seconds- that seems reasonable and sounds about right to me. The OP is talking about a big mismatch in temps between different gauges/sensors that is taking minutes to finally converge. To me that says something else must be going on or be different-- sensor/probe location differences come to mind.
To Digital/Analog Oil Temp mismatch
