Hazard switch EU vs US, difference ????
Old Jan 16, 2016 | 02:40 PM
jmz06's Avatar
jmz06
Default Hazard switch EU vs US, difference ????
Hello,
what is the technical difference between the US and EU hazard switch version (apart from the part number )
Thanks for your help
Old Jan 17, 2016 | 07:15 AM
dadaroo's Avatar
dadaroo
There is nothing in the FSM schematics to indicate a difference so it must be something in the internal flasher.
Mr. Sam
Old Jan 17, 2016 | 07:37 AM
jmz06's Avatar
jmz06
Mr. Sam
I agree with you, the only difference in schematics is the wire connecting the hazard switch to the stop switch
Old Jan 18, 2016 | 02:12 PM
jmz06's Avatar
jmz06
Here is what is written in the FSM regarding the stop lamps & hazard switch
Stop lamps
The STP HAZ fuse in the instrument panel fuse block supplies battery positive voltage to the normally-open stop lamp switch.
Export
When the driver presses the brake pedal, the switch contacts close and the stop lamp output signal is supplied to both left and right stop lamp assemblies and to the center high mounted stop lamp (CHMSL). The stop lamps are grounded at G401.
Domestic
When the driver presses the brake pedal, the switch contacts close and the stop lamp output signal is applied to the CHMSL and to the hazard warning switch. The stop lamp signal is applied from the hazard warning switch to the turn signal switch. The turn signal switch applies the stop lamp switch signal to both of the rear stop/turn lamps, turning them on full bright. The stop/turn lamps ground is applied from G401.
Old Jan 19, 2016 | 05:48 AM
dadaroo's Avatar
dadaroo
I would still think that using a Domestic Hazard switch would work fine in a Euro car. Plenty of people here have converted to Euro taillights with no issues while using the Domestic Hazard switch.
Mr. Sam
To Hazard switch EU vs US, difference ????
