My own front frame savers......
Old Sep 2, 2002 | 01:37 AM
Shinobi'sZ's Avatar
Shinobi'sZ
Default Re: My own front frame savers...... (The Batman)
Nice cheap fix..but I will stick with A&A's.
Old Sep 2, 2002 | 08:16 AM
C5 Frederik's Avatar
C5 Frederik
Default Re: My own front frame savers...... (sweetcharity)
Exactly what I have prepared in my garage but not installed yet. We call it here " Delrin "
I will fix it with two band clamps to avoid to bore holes into the frame.
I´m glad someone else had the same idea.
Good luck
Frederik
Old Sep 2, 2002 | 09:39 AM
white top's Avatar
white top
Default Re: My own front frame savers...... (C5 Frederik)
Batman:let us know what you find out regarding the tape.
C5 Frederik:what do mean band clamps explain please.
Old Sep 2, 2002 | 10:30 AM
C5 Frederik
Default Re: My own front frame savers...... (white top)
Well, the bands/clamps that are normaly on water hoses, with the thread and the little worm to fasten them.
Frederik
Old Sep 2, 2002 | 01:04 PM
sweetcharity's Avatar
sweetcharity
St. Jude Donor '11-'12-'13, '15
Good luck
Frederik
C5 Frederick...Actually Delrin is a bit harder material and somewhat less flexable but it should work fine. I have seen Delrin in various colors (mostly blue) but UHMW only in white. Although someone else posted that it is also availble in various colors. Here's to working ideas :cheers:
Old Sep 2, 2002 | 06:23 PM
C5 Frederik
sweetcharity
went into my garage and tried to fix the clamps, but your solution, using two screws, is much better. Will do it this way.
Frederik
Old Sep 3, 2002 | 11:47 AM
white top's Avatar
white top
sweetcharity:Thanks for the idea & info I plan to use your mod on my car . I didnt like the idea of drilling thru the frame rails to mount wheels seems to me it might weaken the rails.
thanks
Old Sep 3, 2002 | 12:18 PM
THRAP 42's Avatar
THRAP 42
Here's my own design. Used a grade 8 bolt and a wheel that I bought at Home Depot - total cost was <$10.00.
later,
Old Sep 3, 2002 | 02:57 PM
2kbluestreak's Avatar
2kbluestreak
Default Re: My own front frame savers...... (THRAP 42)
I made my own frame saving rollers as a do-it-yourself hobby thing. Bases are formed and welded 310 Stainless Steel that put the load at the bottom of the frame rails, not through a bolt in the middle. Crossbolt axel is a 5/16" dia. aircraft bolt of Inconnel 718. This screws into a flanged bronze bushing on which runs an aluminum wheel. All materials are corrosion resistant, so I never have to worry about rust. Wheel was painted black, but soon wore off making it unsightly shinny metalic. I'm looking for a black plastic material like Polypropolene to either make new wheels or tires for the existing ones. They work just fine. :yesnod:
Old Sep 18, 2002 | 12:28 AM
The Batman's Avatar
The Batman
I visited a couple of hardware stores and didn't find the UHMW tape, but I did find "Magic Sliders" at Home Depot. Patented and trademarked strips about 1" wide and 4" long, backed with rubber. I have some extra-strong double-sided tape stashed somewhere in this pig-sty I call home. I'll post pix when I get a chance. They're not the snazziest color - a kinda greyish bluish shade, but better than the scraped up mix of black and rusting brown that's on my rails, now.
Old Sep 18, 2002 | 02:06 AM
Andy@A&ACorvette's Avatar
Andy@A&ACorvette
Platinum Supporting Vendor
I'll stick with the A&A Frame Savers and Rocker Rails! Oh , wait a minute I'm A&A. Never mind. :rolleyes:
BTW: the combo is still on sale. Hard to beat for the price. ( shameless plug)
Old Sep 18, 2002 | 03:47 PM
white top's Avatar
white top
Default Re: My own front frame savers...... (2kbluestreak)
Just finished your frame rail savers mod ewored out well tanks for the idea &info.
Old Sep 18, 2002 | 04:37 PM
  #33
C5Longhorn's Avatar
C5Longhorn
This would be great in conjunction with Andy's wheelies and frame savers.
Old Sep 18, 2002 | 04:43 PM
  #34
gojo's Avatar
gojo
Thanks for the idea. I'm always hitting parking curbs. I installed them last week. It is one of those simple but great ideas.
Old Sep 18, 2002 | 05:08 PM
  #35
sweetcharity
Default Re: My own front frame savers...... (jfpilla)
Thanks for the positive replies guys. Right, a simple idea that works! :cool:
Old Sep 24, 2002 | 03:31 PM
  #36
gojo's Avatar
gojo
sweetcharity, want to thank you again. I've hit parking curbs twice. No damage. The C5 guys in my Vette Club are putting them on.
Old Sep 24, 2002 | 05:30 PM
  #37
sweetcharity
:yesnod: :yesnod: Thanks for the thanks! I guess I should have made a pile of them and offered them out there!!! Mine have also been tested twice :mad but are unmarked so far.
