Radiator cover bolt size
Old Feb 1, 2016 | 03:21 PM
nullpointer's Avatar
nullpointer
Default Radiator cover bolt size
I took off my radiator cover (black piece with 2 bolts on each side that lays over the radiator) during my blower install. Then I moved and now I can't find the bolts. What sizes are they? Most I can get from searching is M6.
M6 - 1.0 x ??
Correct pitch??
What length??
Thanks!
Old Feb 1, 2016 | 04:05 PM
LoneStarFRC's Avatar
LoneStarFRC
It's a bit of an oddball. Pointed tip with a captured washer. It does NOT appear to be "6mm" but rather a "6.3mm"
GM part number 10284014
GM description: BOLT RAD SUPT,(M6.3X1.27-25 HEX HD),
Here's a box full pic from some bulk seller:
If it were me and I wanted OEM, I would call Marc @ Vettenuts
1-615-896-6100
HTH
Old Feb 1, 2016 | 08:50 PM
I'm sure Marc can help you out.
To Radiator cover bolt size
