driveshaft has a slight wobble
Also, I have vibration in the motor at 2k and 4k rpm. It persists in all scenarios that I could test.
Driving normally in all gears
revving the motor with clutch depressed and transmission in neutral
revving the motor with clutch depressed and transmission in 1st
revving the motor with clutch engaged and transmission in neutral
I kind of figured that would be a motor mount issue because revving with clutch depressed and transmission in first means the drive shaft isnt spinning. Also, the harmonic dampener is new and not wobbling.
Thanks!
Sounds to me like a HOT BALANCE issue..
You could also have a slight vibration if the Harmonic Damper has been replaced. Is yours original??
BC
Bill
That being said,, what would have changed to cause a NEW vibration??
Thoughts:
1. Pilot Bearing
2. Damaged pressure plate
3. Torque Tube Bushing/s
4. Torque Tube Bearings
5. Cracked Bell Housing (Mine was cracked but didn't know it. Hair Line)
6. Loose or missing bell housing or torque tube bolts. (Seen that a few times)
= Yes,, if the prop shaft is bent/wobbles, it could flex and cause a weird vibration.
Bill
Thoughts:
1. Pilot Bearing It does look damaged. maybe thats it
2. Damaged pressure plate Looks fine
3. Torque Tube Bushing/s Look fine
4. Torque Tube Bearings Seem to be in good shape
5. Cracked Bell Housing (Mine was cracked but didn't know it. Hair Line) It's off now. I'll check it to see if there are any cracks
Next thing that I would do would be to pop off the bell housing inspection plate and see if you can see or hear anything abnormal.
Bill
Thoughts:
1. Pilot Bearing
Bill
I didn't have a 100% confirmation that the procedure was still being conducted. Thanks
Bill
I guess I'll hold off on installing the weights. I do have the original flywheel/PP (my hoarder instinct is paying off) so I may look for a machine shop that can compare the two and make adjustments if needed. I'll get a video of the drive shaft wobble to see if anything looks off to anyone.
The engine balance is fine AS ASSEMBLED without any further external balancing. The build tolerances on all components are all tight enough to make as built engine balance very good for engine reliability and operation. LS engines going in to automatic vettes ARE NOT HOT BALANCED.
HOWEVER
Due to the different vibration transfer paths inherent to the manual transmission vette's design, and its NVH impact, LS engines going into manual transmission vettes ARE further externally balanced via the hot balance procedure. It is to get TOTAL engine assembly balance DOWN EVEN BETTER than what is required for engine reliability, strictly for NVH purposes, to minimize vibrations transmitted into the cabin. This is unique to vettes because of the split engine/transmission design, connected with the rigid torque tube.
You are in good shape if you have your stock FW/PP. Keep them. Put them together see what their state of balance is, as the COMBO. That will give you a starting point, as far as balance goes.
As far as the propshaft wobbling, I'm not clear what you are describing. Just the elastomeric couplers and length of the shaft will allow a little "flex". The shaft guide at the center of the propshaft ( I don't know what it is actually called) helps keep the spinning propshaft from flexing too much. If you have "play" in your bearings, that's a whole different ballgame.
PS: when I CAPITALIZE words, I am not yelling, I'm just trying to highlight important sections. So as not to tick anyone off.
That is exactly what I wrote. One roller bearing on the input shaft.
Hey Bill,
CHECK THIS OUT.
https://www.corvetteforum.com/forums...ndbuilt-2.html
post #26 is a video of the hand build LT4 and LS7, current procedure.
timestamp 8:56 shows the hot balance, and balance weights. Notice the entire engine ins in the balance stand, WITH BOTH the flywheel and pressure plate installed.
Yet, there will still be people who won't believe it is done.
