Fog Lights...........................
Old Aug 31, 2002 | 08:15 PM
rayjerman's Avatar
rayjerman
Default Fog Lights...........................
I bought some fog lights today and was wondering if there is a way to wire them into the daytime running lights or the headlights. Thanks.
Old Aug 31, 2002 | 11:39 PM
C5Cemo's Avatar
C5Cemo
Default Re: Fog Lights........................... (rayjerman)
From what I've read, the wiring for the stock fogs is on your car. You just need to hook em up or wire them in and get the switch panel that has the fogs and trunk switches on it from a dealer. I'm almost 100% certain that this is all you need to do. Hopefully someone who has done the install will chime in.
Old Sep 1, 2002 | 02:33 AM
Ram Air Tony's Avatar
Ram Air Tony
Default Re: Fog Lights........................... (C5Cemo)
Cemo is correct.......just get the factory switch panel, and the wiring and relays from the switch to the under hood fuse box is there.......you will have to mount the lights, and then wire them to the #6 fuse (i think that is it from memory) in the under hoood fuse box :)
done deal
Old Sep 1, 2002 | 03:42 AM
C5Cemo's Avatar
C5Cemo
Default Re: Fog Lights........................... (Ram Air Tony)
R
A
T...to the rescue again :yesnod: :D Thanks for the clarification. :cheers:
Old Sep 1, 2002 | 09:46 PM
rayjerman's Avatar
rayjerman
Thanks guys!
Old Sep 2, 2002 | 12:26 AM
Ram Air Tony
R
A
:D
thanks
R
A
T
To Fog Lights...........................
