Max speed 80 mph??
Old Sep 1, 2002 | 11:11 AM
martin97c5's Avatar
martin97c5
Default Max speed 80 mph??
start up my car this morrning and the dic says "maxspeed 80 mph"
i didnt know y it said that so i hit the highway and it is governed at 80?why did that happen?
i then pulled over and restarted my car and i could pass 80 mph
whats goin on?
thanks for any advice
martin
Old Sep 1, 2002 | 11:23 AM
Lil Red's Avatar
Lil Red
Default Re: Max speed 80 mph?? (martin97c5)
I wish I could help you out on that one cause god knows I don't ever want to see that messege :eek: It will be interesting to see the responses that you get get as to why that happened.
Old Sep 1, 2002 | 12:18 PM
WWK888's Avatar
WWK888
Default Re: Max speed 80 mph?? (Lil Red)
I assume you checked your DIC for codes?
Old Sep 1, 2002 | 12:24 PM
Joe C5 Coupe's Avatar
Joe C5 Coupe
That's really strange. At least you didn't get a maxspeed 40 :crazy:
Old Sep 1, 2002 | 12:29 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Problems with ABS, TC & Active handling as well as F45 shock system malfunctions can cause this to be displayed on the DIC. Take it to the Dealership and let them fix it.
vetterdstr :cheers:
Old Sep 1, 2002 | 12:45 PM
billiam01's Avatar
billiam01
It's probably the black box acting up when you speed too much! :D
Old Sep 1, 2002 | 01:29 PM
PaceThis's Avatar
PaceThis
IF AH/TC/ABS systems can cause this...maybe...
When you start your can and start driving before these systems initialize, they all give an error. Maybe this is the cause and it limited your speed as it hadn't properly checked all systems...shot in the dark...
Old Sep 1, 2002 | 01:34 PM
BQuicksilver's Avatar
BQuicksilver
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Max speed 80 mph?? (PaceThis)
I'm not exactly sure what causes it, but I know that the reasons were described in the owner's manual when I read it. Might be a good to time to look.
Old Sep 1, 2002 | 09:58 PM
martin97c5's Avatar
martin97c5
Default Re: Max speed 80 mph?? (BQuicksilver)
thanks for all the replys
To Max speed 80 mph??
