Keep radio on during engine start?
Old Apr 15, 2021 | 04:15 AM
Sereno011's Avatar
Sereno011
2nd Gear
The most efficient method would be to use a 1000uf 25V capacitor, 1K resistor and diode.
Cut the ACC wire from the OE (or aftermarket) harness.
Wire the resistor and diode in series to the + of the capacitor.
Solder the ACC (vehicle side) before the resistor/diode going to the + cap.
The radio ACC wire get soldered after the resistor diode closest to the + leg of the cap.
Finally ground the - lead of the cap.
-------------- R - ------- D ----------------- --- + C - --
Car ACC ---/\/\/\----[ ||]----(Radio Acc)------|(-----(Gnd)
For any relatively modern radio (OEM or aftermarket) a 1000uf cap is sufficient for 5-8 sec which should be plenty for normal cranking.
A greater uf cap will work too though IMO 1500uf at max or it will keep the radio on a little too long.
Resistor isn't necessarily required but used to protect the diode & cap from the initial in-rush current while it charges.
A 16V cap will work in a pinch but is cutting it close to charging voltage so 25V or greater is recommended.
Old Apr 16, 2021 | 10:38 AM
grinder11's Avatar
grinder11
Since he's had over 5 years to figure it out, I'm sure he's got it right by now. Just sayin'........
Old Apr 16, 2021 | 09:45 PM
Sereno011's Avatar
Sereno011
2nd Gear
True. But the original poster isn't the only one who will read this post.
Old Apr 17, 2021 | 04:36 PM
grinder11's Avatar
grinder11
Also true.....
