Hard shift
Old Feb 19, 2016 | 09:33 PM
Kannall's Avatar
Kannall
6th Gear
Default Hard shift
Hey I just bought a 1998 automatic C5 and when I put it into gear it shifts really hard. It also shifts hard into 2ND . Anyone know why?
Old Feb 20, 2016 | 02:33 AM
grantv's Avatar
grantv
A little hard to understand your post. Does it clunk when you put it in gear or just shifts hard? Maybe the PO had the tranny modified. Is the car mostly stock?
Old Feb 20, 2016 | 02:41 AM
Kannall's Avatar
Kannall
6th Gear
Default No clunk
It just shifts really hard and no it is not stock in has had some work done to the engine and exhaust
Old Feb 21, 2016 | 08:23 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
First things to check (do you have any DTCs in the DIC?)
When was the last time that you checked the fluid level of the trans?
BC
Old Feb 21, 2016 | 08:31 AM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
I would say that it has engine mods and possibly still has the stock torque converter. With higher RPM's needed for idle speed it would cause the car to go from Park to Drive hard. Do you have a list of the things done to the engine and driveline?
Old Feb 21, 2016 | 08:37 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Also, you could have a Torque Tube bushing issue if there is any noise related in and between shifts.
BC
Old Feb 21, 2016 | 06:38 PM
thumpinc5's Avatar
thumpinc5
The 1998 C5 uses the 4L60E transmission. These transmissions used a variable force motor to control pressure. If the solenoid has failed or if it's unhooked, it will default to maximum line pressure. This will cause a firm engagement and firm shifts. There are also various codes that will cause it to default to maximum pressure. Pressure is also able to be raised through the tune. Is it possible that it's been raised? As already mentioned, this could be too much play somewhere in the drivetrain as well. The best place to start is to pull the codes. If there are none, I would put a pressure gauge on the trans to confirm what the pressure is.
To Hard shift
