Headlights dim when windows lowered
Old Sep 2, 2002 | 12:42 AM
StormCrow's Avatar
StormCrow
Cruise-In III Veteran
Default Headlights dim when windows lowered
If my headlights are on, they dim every time I press window switches. Is this normal? Has anyone else experienced this?
Old Sep 2, 2002 | 02:36 AM
BubbleHead's Avatar
BubbleHead
Default Re: Headlights dim when windows lowered (StormCrow)
Do they go dim the whole time your windows go down or just for a second? Sounds like your battery may need replacement if they dim the whole time.
Old Sep 2, 2002 | 03:00 AM
vk's Avatar
vk
Mine dim any time you press the window up or down button. If you hold it down while driving, the lights keep dimming. From what I understand this is normal and seems to just happen because the car draws too much power or something
Old Sep 2, 2002 | 07:43 AM
steve badalamenti's Avatar
steve badalamenti
Normal :yesnod:
Old Sep 2, 2002 | 09:20 AM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
Default Re: Headlights dim when windows lowered (steve badalamenti)
Normal :yesnod:
Old Sep 2, 2002 | 10:48 PM
JohnS's Avatar
JohnS
Must be normal, but ridiculous. I replaced my battery with the optima yellow and the problem is not as bad, sometimes not even noticable.
JohnS
Old Sep 3, 2002 | 01:01 AM
StormCrow's Avatar
StormCrow
Default Re: Headlights dim when windows lowered (vk)
That's exactly what happens to me. Glad it's normal. Thanks guys!
Old Sep 3, 2002 | 01:06 AM
Avanti's Avatar
Avanti
Normal. :yesnod: However, there are degrees. Any high-drain switch-on will dim the lights a bit, sometimes for just an instant or two until the system compensates. Some take longer than others; often a window going down or up takes such a short time, it stays dim the whole time.
[Modified by Avanti, 11:07 PM 9/2/2002]
To Headlights dim when windows lowered
