Are coolant temperature fluctuations normal?
Old Mar 3, 2016 | 06:31 PM
uz1290's Avatar
uz1290
Default Are coolant temperature fluctuations normal?
Hi all,
I did some preliminary research on what coolant temperatures were considered normal as I felt that my c5z was running a little on the hotter side.
While highway driving I get temperatures from 190 to 200 F degrees.
However, in stop and go traffic around here, my temp climbs to about 226 to 230 F degrees.
I read a couple of previous forums and the temperatures all seem to be in the "normal" range. I have never ran into overheating issues, but I can't seem to convince myself that this is normal operating temperatures.
Are these fluctuations really that normal? Also, am I not on the hotter side of the temperature spectrum? I would appreciate any feedback. Thanks in advance!
Old Mar 3, 2016 | 06:47 PM
Smoken1's Avatar
Smoken1
Absolutely normal
HAHA 8VETTE7 beat me to it
Old Mar 3, 2016 | 09:08 PM
Paul 75 L82's Avatar
Paul 75 L82
If my Z hit 230 I would be buying new parts. I don't agree with these high temps being normal. Start out with cleaning your rad and you AC condenser.
Old Mar 3, 2016 | 09:31 PM
uz1290's Avatar
uz1290
Thanks for feedback guys. I guess they are in the normal range, but I've just never had a car that fluctuated so much. Most cars I've had just stay stuck at one temperature (usually middle on gauge) and don't move much from there. I'm assuming with the corvettes being bottom feeders this might attribute to some fluctuations.
Old Mar 3, 2016 | 09:33 PM
uz1290's Avatar
uz1290
I actually bought some parts off a couple of guys on Craigslist and they agreed with your belief. As in, the car is running too hot. At this point I feel like I'm getting two yes's. Some say it's normal, some say it's hot.
None the less, I have never cleaned any cooling system components on my c5z so I will definitely put that on my bucket list.
What other parts would you be changing if you don't mind me asking? Thanks
Old Mar 3, 2016 | 11:03 PM
wrmiles's Avatar
wrmiles
It depends on how hot it is "around here". In a warm to hot climate, 220-230 is not at all unusual when not moving or moving very slowly.
Look at it this way. The electric radiator fans do not come on until 226. Of course it is going to get about that hot.
Old Mar 3, 2016 | 11:22 PM
uz1290's Avatar
uz1290
Sorry about that, I thought my location was in my signature or whatever. But yea, I'm in central Texas, specifically Austin, so we definitely get some hotter climates.
Thanks for the reassurance, I seem to be overthinking the whole thing. Lol.
Old Mar 4, 2016 | 05:35 AM
Cybermind's Avatar
Cybermind
Both the fluctuations and those temperatures are completely normal. Don't waste your time trying to fix something that isn't broken. The C5 was designed to run hot.
Of course you should make sure that the rad has no restrictions and/or buildup of junk underneath, but apart from that.......enjoy the car.
Old Mar 4, 2016 | 09:34 AM
uz1290's Avatar
uz1290
Originally Posted by 8VETTE7
If you turn on the AC when the engine temps start climbing the cooling fans come on at 185 rather than 226 without the AC on. Unless your radiator fins are heavily clogged, the temps should stay below 230.
If the fins are plugged up then all bets are off as to how hot the car will get......
Paul 75 L82 stated in the thread I referenced above that he had the turn on temps for his cooling fans lowered from the factory defaults. So chances of his car getting to 230 are probably pretty small...
Good point that you make there. I believe the person who sold me some parts here locally (who also said I was running hot) had done some tuning to his car, most likely resulting in much cooler operating temperatures.
Old Mar 4, 2016 | 09:37 AM
uz1290's Avatar
uz1290
Thanks for the peace of mind, I will definitely look into cleaning the radiator regardless as I don't think that would hurt any.
But the general consensus is that these temperatures and fluctuations are quite normal. Thanks for all the feedback!
Old Mar 4, 2016 | 12:53 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
CLEANING THE RADIATOR:
There is a 1" space between the AC Condenser and the actual radiator. That space can and will get clogged with GRASS, DIRT, LINT, ect....
You have to remove the radiator to actually do a 100% job on proper cleaning the fins. You can try to BACK flush it with the direct stream of a garden hose. DO NOT USE A PRESSURE WASHER!!!!!!!!!!
Make sure that your antifreeze to water mixture is proper for your area. NO NEED to be protected to 50 Below Zero!
You can reprogram your fans to come on sooner and stay on longer.
You can get a colder thermostat. (which goes along with reprogram your fans to come on sooner and stay on longer.)
Make sure there isn't any trash in the air entry for the cooling system and all your air dams are in place and functional.
GM Changed the coolant cap relief pressure to 18 lbs. If you have an old cap, get a new 18 lb cap.
Bill
Old Mar 5, 2016 | 09:55 PM
sirdano's Avatar
sirdano
I bought mine last July here in Austin. And yeap it is normal. Mine did the samething. You can put the AC on and it will keep it a little cooler for a while.
Also mine has a small leak at the overflow container were the top hose connects. Replacement is $80.00.
Old Mar 5, 2016 | 10:57 PM
uz1290's Avatar
uz1290
Good to know we're on the same page!
Are you sure we didn't buy the same car? Haha
Mine had a leak in the exact same spot, the plastic where the hose connected was pretty much toast and was just breaking away little by little. Got a sweet deal on a reservoir tank on CL, you should take a look every once in a while if it's something that might need replacement soon.
Old Mar 5, 2016 | 11:53 PM
sirdano's Avatar
sirdano
Kind of worried about buying used might have same issue or another one. Will just wait until it get bad. Only really small now. Will try and get a house clamp (instead of crappy spring one) and push hose completely over area might hold.
Hey since we are in same area you see a white white tan conv top it me!
Old Mar 6, 2016 | 11:09 PM
73Corvette's Avatar
73Corvette
Bill
SPOT ON
To Are coolant temperature fluctuations normal?
