Beehives or Duals?
My though it that the lower spring pressure of the beehives will be easier on the entire valve train and help the long term. This isn't a race application so the safety net of the duals seems less important. But, max lift for beehives is .600 lift, which is exactly what the 224R is. So, am I testing the limits of beehives with this cam? There are some beehives good to .625" - should I go that route? The price difference is $100+/- - that's not the issue, just trying to put the correct setup together.
The rest of the set up is 01, 6M, catted longtubes w/Tis, cold air. The stock 241s will be ported/polished when the cam goes in. Oil pump and timing chain too.
Thanks for the input.
PAC or PSI make beehives that are good past .600 lift.
Yeah, you have some more insurance with dual's but you also are adding in extra valve-train weight. Maybe for a low redline build it not such an issue...
http://www.hotrod.com/how-to/engine/...-valvesprings/
Part of their Endurance Series. Good to .625http://psisprings.com/index.php?opti...les&Itemid=155
HTH
The only issue we had was about 10 years ago. One of the springs broke (the kit came with REV dual springs). The inner, second spring, saved the internals. The car still ran, just didn't like to start or idle well. We replaced all the springs with Patriot Gold duals. They are still running just fine today. Personally, I like the added safety of a dual spring for that just in case situation....
Its my Understanding from researching and reading that there isn't one person who has had a failure with PSI beehive springs which is why I went with them. That and the fact that they don't need to be replaced every certain amount of miles sold me on them.
The responses in this thread have about 50/50 with good points for each option.
Some of the Mechanical or Material Engineers can correct me if I'm wrong (I'm a Civil Engineer), but I think the earlier spring issues were more a function of the materials being used than single vs. dual. Some of the earlier high-perf single springs needed to be made out of unique alloys to get a certain stiffness for .600+ lifts in a given spring diameter and height. Those same alloys, while offering the high strength (spring rate) needed did not have fatigue resistance like "lesser alloys" did. This would cause the springs to break after a certain number of cycles (hence the mileage limitation). This is similar to what happened in some building designs years ago when designers began specifying very high strength bolts for structural connections (more in my area of knowledge). The failures were traced to the bolts' alloys not having sufficient fatigue resistance, even though they were very strong. Basically as wind loads and stuff on the buildings "flexed the connections, the bolts were "loaded" and "unloaded" (cycled like a valve spring). The alloys didn't like that; they did great in situations where they applied a certain amount of load and then held it constant.
Today, there are different alloys and different spring designs and I'm not sure it is an issue like it was. If it still is an issue, then I would submit that a dual spring becomes a better alternative. A dual spring arrangement allows you to combine the strength of two springs. This means each individual spring can be made out of "lesser exotic" alloys to accomplish the same goal. Tried and true materials with OEM fatigue resistance (longevity) can be used so you don't have to swap springs every 30k miles.
To this day, I can't say definitively why I had my one spring failure. I really didn't dig into it that hard when it happened. I did look at the failed spring with a cheap (very cheap) magnifying glass and it looked like there could have been a slight material flaw where it broke. I also can't say exactly how many miles the car was driven with a broken spring. I can say it was driven at least for a couple of weeks which included at least one highway trip (couple hundred miles). At the time the break occurred, the car still hadn't been tuned. It would idle rougher and sometimes die at a stop because of the lack of tune, so it took me a little to recognize that it was actually not running quite right. The hard start and that it started acting that way all the time versus kind of periodically finally turned the light bulb on that I had an issue. I could have likely gotten away with just replacing the one spring. Instead, I chose to go with a newer dual spring (rated to handle a little more lift) for piece of mind....
