Gasket Removal Help - Harmonic Damper
I'm replacing the HB on my sons '98 c5 and the gaskets are easy to remove and the surfaces are easy to clean up.
BUT, BUT,
The water pump has a GM Paper(?) gasket or some aftermarket "black" glue gasket. So far nothing will soften or remove it (brake fluid, Permatex Gasket Removal, paint thinner, Acetone, etc.). I'm trying to scrape it off with a razor blade but I'm putting nicks in the aluminum of the water pump mating surfaces.
I'm not really afraid of slight nicks and scratches but I'm working on my son's car and I'd like to this correctly and be able to use the new style gaskets. (Me, I'd go old school and use gasket material with Permatex on both sides.)
Suggestions ? -- or don't worry about it ..
BUT, BUT,
http://3mcollision.com/products/abrasives/bristle-discs
Cheers,
Goose
BUT, BUT,
Thats cool though you're fixing your sons C5, my Dad mainly
bickers at me to sell mine everytime I have fix something on it lol.
If you lay the razor blade almost FLAT and rock it side to side, it will get under the gasket and not damage the surface.
Fairly quick way of cleaning and leaves a perfect surface (IMHO). Thanks to all and I hope this helps someone else.
