275/40/17 on front
Old Mar 11, 2016 | 07:34 PM
billvh's Avatar
billvh
Default 275/40/17 on front
I have 10" wide aftermarket rims, I'm going to put 275's on front, anyone had issues with this size?
Thanks!
Old Mar 11, 2016 | 08:05 PM
phil hunter's Avatar
phil hunter
I have 275/40/17's on the front on 9.5" rims. No issues.
Phil
Old Mar 11, 2016 | 08:22 PM
billvh's Avatar
billvh
Phil
Thanks, now that you mention it, mine are 9.5" too rears are 10"
Old Mar 11, 2016 | 08:43 PM
Patches's Avatar
Patches
I run 275/30/19 (10") on front and 305/30/19 (11") on rear, no problem
Old Mar 12, 2016 | 07:42 AM
vettenuts's Avatar
vettenuts
Curious why you are doing this? Reason I ask is my car has Z16 rims (polished GM Z06) and there are no tires available. I can get the correct rear but not the front, or vise versa. If I go with the size you are looking at it opens up several different tires that would be available.
What are you running in the rear?
Old Mar 12, 2016 | 10:19 AM
billvh's Avatar
billvh
I am running 285/40/18 in the rear, the 245's on the front rims are kind of stretched on the front. The front tires are 10 years old, so I am going to replace them. Just wanted to make sure the 275's don't rub. They are the same diameter as the stock fronts, so speedometer will be ok.
Old Mar 12, 2016 | 10:50 AM
phil hunter
I'm running the previously mentioned 275/40/17 up front and 305/35/18 in back on C5 Z06 wheels with no issues.
Phil
Old Mar 12, 2016 | 11:16 AM
Rx7Rob's Avatar
Rx7Rob
I run 275-40-17 and 305-35-18 NT01's on my Z16 rims. Car is a 2000.
The front is the same diameter as the stock 245-45-17s that came on my car. Its 12% wider.
Ther rear is 1/4" smaller in dia (less than 1% change) than the stock 275-40-18. Its 11% wider.
Old Mar 12, 2016 | 02:41 PM
toycloser's Avatar
toycloser
Nitto 555 275/40/17 here. No rubbing issues but my power steering pump gets a little noisy sometimes.
Old Mar 12, 2016 | 04:38 PM
vettenuts's Avatar
vettenuts
Thanks. I am considering the Continental Extreme Contact DW.
Old Mar 12, 2016 | 04:55 PM
billvh's Avatar
billvh
Those are the tires I have on back now, just need them for front. Dealer tore up bead while replacing TPS, gave me free tire, so I replaced the other rear too. They were 9 years old anyway, so it worked out! Now doing the front.
Old Mar 13, 2016 | 12:19 AM
toycloser's Avatar
toycloser
I have had those on 2 different cars and loved them. They wear great, stick well, look good and stick well.
To 275/40/17 on front
