stand Alone PCM wire question(s)
Old Mar 12, 2016 | 11:53 AM
Gxpz06's Avatar
Gxpz06
Default stand Alone PCM wire question(s)
the first one for starters Is the VSS (vehicle Speed Sensor) ..
on my T56 drag car (soon) do I really NEED to Imput any speed information to the Transmission sensor for any good reason?
Reason I ask and hope I dont need is because I got a Great looking ENGINE wire harness to convert the stock pcm to Stand alone ANd I am Awaiting the response if the VSS plug on this harness is an input or output... If its an Input then I would just plug it in to one wheel sensor to send speed info to PCM ,. then I wouldnt plug anything into the t56 ...
I eliminated the BCM so I dont have any speed info coming in to the pcm... if the new harness is An output Ill be scratching MY head for a while how to input speed into the Factory ECU/pcm
thanks in advance for any Input pun intended
Old Mar 12, 2016 | 08:18 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The VEHICLE SPEED SENSOR is on the DIFFERENTIAL. You can NOT use a wheel speed sensor for vehicle speed.
There are ZERO speed sensor wires on the T56....
Only wiring should be on the T56 is:
Reverse Lock Out Solenoid
CAGS 1st to 4th shift solenoid
On a ZO6 there is a Trans Oil Temp Sensor inside the Oil Fill Port instead of a pipe plug.
VSS Differential:
(top of picture, passengers side of the case)
Old Mar 12, 2016 | 08:25 PM
Gxpz06's Avatar
Gxpz06
THANK YOU Bill... so how does the Diff get its speed inputed in order to output it to the PCM ?
Old Mar 12, 2016 | 09:32 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Well,, Here is a schematic that you need to have:
other schematics to follow
Old Mar 13, 2016 | 01:00 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
How the WSS connect into the system:
Old Mar 13, 2016 | 01:18 PM
Gxpz06's Avatar
Gxpz06
THanks.. I have 0 wires in the car and no fuse boxes .. So just wondering where I can get the speed to input into the pcm ... you say not wheel sensor directly? or does the Diff VSS calculate speed as it turns and sends it to PCM>?
Old Mar 17, 2016 | 04:36 PM
Gxpz06's Avatar
Gxpz06
next 2 questions which is the HOT wire for stock key ignition and Starter --- ?
2nd which is the HOT wire from the wire pump at pumps?
thanks in ADVANCE
Old Mar 18, 2016 | 12:46 AM
lionelhutz's Avatar
lionelhutz
I'm not sure if you got the VSS question answered, but the sensor is in the diff (the output) and it connects directly to the PCM (the input). The harness should have a VSS wire you just connect to the diff sensor. If it's a stand-alone harness for an engine and transmission bolted together then you'll have to lengthen the wires.
The BCM doesn't provide a speed signal to the PCM, nor do the wheel sensors.
Old Mar 18, 2016 | 06:08 AM
Gxpz06's Avatar
Gxpz06
yes Thank you I stareted to figure that....
Old Mar 18, 2016 | 11:38 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
thanks in ADVANCE
Here is a diagram/schematic for the ignition switch feeds.
This is a 1999 Schematic. The fuse references will be different for other later model years:
Old Mar 18, 2016 | 12:57 PM
Gxpz06's Avatar
Gxpz06
thanks bill ... by that schematic It looks like I would run the 2 red to 12v battery ,. the yellow to starter ("crank" at fuse) and the brown to Ignition off Pcm ..
Ill give it a shot and let know the outcome in few days..
lastly need to know which is power wire from the rear wires coming off the fuel pumps.... ?!
thanks in advance
Old May 11, 2016 | 06:57 AM
Gxpz06's Avatar
Gxpz06
thanks in advance
SOrry it was the pink to IGnition and works fine ... I used no maxi fuses but think ill add that tonight in line
Old May 11, 2016 | 01:32 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Here is the OEM fuel pump schematic. I believe this is an early system.
To stand Alone PCM wire question(s)
