Need help with Ebmc/SWPS
c1248- embc turned on red brake warning lamp
c1254- abnormal shut down detected
c1281- vses sensor uncorrelated
c1284- lateral accelometer sensor bias malfunction
c1285- lateral accerometer sensor circuit malfunction
c1287- steering sensor rate malfunction
c1288- steering sensor circuit malfunction
sdm & ipc have u1040 code- no comm with the ebcm
I started doing research on these systems, and found alil on how they work. It seems to me as they are tied together. They then removed the used module(forum member), and reinstalled the original(rebuilt unit) and they still have the exact same codes. They rebleed the system. no help. same codes.
My questions:
1. Do the steering wheel shaft needed to be disconnected to drop the drive train from the bottom? I'm asking this, because I read if its disconnected, and the steering wheel is moved while its disconnected, it can cause a lot of issues.
2. Should I just buy a dealer Ebmc, and a swps? Really don't like throwing parts at it. But will know these 2 components are 100% ok.
3. Can the hydraulic side of the ebmc, cause these promblems?
4. Do I have another wire issue somewhere?
Again, I'm in the sandbox, and cant do it myself. I will make recommendations to the guys whom are working on my car. They don't have a lot of experience with this system. Thanks for reading, and any and all help is greatly appreciated.
Check ALL the fuses to the EBTCM There are MULTIPLE fuses. Test the actual VOLTAGE on top of the fuses (two test slots on the fuse) to chassis ground. MAKE SURE that they are receiving full battery voltage at each fuse!!
The ground for the unit is at G-101 directly aft of the drivers head light & at the ground lug on the frame near the battery G-108.
Make SURE that the EBTCM connector is properly connected and the lock bail on the connector is fully shut.
Measure power AND Ground directly on the EBTCM Connector with a meter:
Here is a schematic for you:
Thank You for serving brother!
Bill
my other codes if you think they are related:
p0103- from tuning
u1040
abs- c1248, c1254
bcm- 2648
hvac-b0363, b0441
u1096
thanks again all.
The dynamic rear proportioning (DRP) is a control system that replaces the hydraulic proportioning function of the mechanical proportioning valve in the base brake system. The DRP control system is part of the operating software in the EBCM. The DRP uses active control with the existing ABS in order to regulate the vehicle's rear brake pressure.
C1254 DTC is set when the microprocessor compares a periodic checksum to a running checksum and finds they do not match. The checksums are areas of the computer's memory that hold critical operational data. Possible causes include: loss of battery ground, disconnected battery, computer malfunctions, sudden drop in system voltage below 5 volts, long extended engine cranks that cause battery voltage to drop, poor power or ground connections.
Looks like you may need a Tech2 to run a system check. If all the wiring checks out, and the test says it fails, looks like your gona be replacing the EBCM
Also, after reading up on this point, I will never jump start my 2000 with a battery pack or cables, it stays on a tender 24/7 365 days/year..
