emergency brake adjustment
Old Sep 3, 2002 | 02:12 PM
highlander's Avatar
highlander
Default emergency brake adjustment
It's probably been discussed a million times before but...........I need to tighten my emergency brake on my 2000 coupe. Is it done under the car or at the handle. Removing the center council easy or ???
Highlander
Old Sep 3, 2002 | 02:15 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Default Re: emergency brake adjustment (highlander)
Are you referring to the brake itself not holding the car???? If so you adjust at the wheels....other than that I can not advise.
Old Sep 3, 2002 | 02:28 PM
Fahtrim's Avatar
Fahtrim
Default Re: emergency brake adjustment (pewter99)
There have been many posts here. Here is what I have saved off.
This post seems to resurface every few months. My parking brake was so bad that it basically was non-existent.
I chased the car twice and said enough is enough. So, take notes, because here is what I did to fix it.
1. Lift the car up from the rear axle crossmember, place 2 jackstands on either side, so that the entire rear is off the ground.
2. Remove the rear wheels, then make sure the parking brake is down.
3. Remove the caliper by removing the bolts attaching it to the hub. It should slide off, you can then sit it on the axle behind it.
4. The rotor should come off with a little twisting. A few taps with a rubber mallet may help.
5. On the side closest to the rear of the vehicle (ie. right on driver - left on passenger), you should see a star-shaped nut that turns.
That nut lowers, raises the upper pad that contacts the inside of the rotor.
It sometimes helps to spray brake parts cleaner over this assembly to make it easier to work on.
6. To adjust this the easy way, take a flat-head screwdriver and wedge it behind the nut and push out, this is the quickest way.
To turn it the other way you'll need pliers.
7. Adjust it a bit and then try to put the rotor back on.
If it doesn't go, don't force it, just turn the nut back a turn or two and try again. Do this until you can put the rotor on.
8. Reassemble the side, minus the wheel, then do the other side.
Once done on both sides, put the wheels back on, lower the car, and torque the wheel bolts correctly.
Old Sep 3, 2002 | 02:43 PM
highlander's Avatar
highlander
Thanks, I would have thought there was a cable adjustment. I pull the handle all the way up and the emergency brake only holds on the flat. On a hill, forget it.
Still adjust at the wheels? Are the caliper bolts the two large ones 14 or 16 mm on the back or are they the two allen heads with the rubber boots.
Old Sep 4, 2002 | 02:36 AM
alc2001's Avatar
alc2001
Cameron - You need to remove the brake caliper mounting bracket to get the rotor off so you can get to the star wheel adjuster. The bolts that hold the mounting bracket on take a 21 mm socket and a long breaker bar. They are hard to break loose. The service manual says to discard the old bolts and replace with new ones. They have a pre-painted stripe of locking adhesive on the threads. I cheated and reused the old bolts with Loctite. The torque spec is 125 lb-ft. Check this thread: http://forums.corvetteforum.com/zerothread?id=349088. Good luck!
Alan :seeya
Old Sep 4, 2002 | 02:50 AM
MRWHOOPPEE's Avatar
MRWHOOPPEE
Default Re: emergency brake adjustment (alc2001)
Isn't there a hole in the rotor to get at the star adjuster ?
My C4 did.
Haven't had to do my C5 yet :)
Old Sep 6, 2002 | 12:57 AM
alc2001's Avatar
alc2001
Default Re: emergency brake adjustment (MRWHOOPPEE)
My C4 did.
Looks like the C5 took a step backwards in that regard. There is no access port in the backing plate.
:mad
To emergency brake adjustment
