I am trying to get my 2004 C5 through California emissions testing this year and have an issue with two readiness monitors not resetting, the Evaporative system and the Catalyst monitoring. The car was modified with STS twin Turbo system (C.A.R.B. approved) in 2011 and has gone through emissions testing twice since then with flying colors. Now with this condition it won't pass. I'm in the process of putting it through some drive cycles as I have read a couple of posts and articles and all have suggested driving the car between 55 to 65 mph for 5 to 10 miles. I have checked the codes and there are none. I did have an issue with the Fuel trim but we found that and fixed that, (air leak at the connector hose to the air bridge over the radiator). All codes have been cleared now and all other monitors are set. The tech also did a "level 6" (that's what he called it) where he used an exhaust monitor and indicated the car was running very clean. His recommendation was to take it out and drive it.
Has anyone run into this before and if so what did you do.
55 to 65 mph for 5 to 10 miles. May not get them set I ran into this with many Honda cars. You can get a cheap scanner that will show if the monitors are set
LOL 8VETTE7 got here b/4 me
Clearing PCM codes and disconnecting the battery BOTH will reset the readiness monitors to NOT ready. THe C5 buily in code reader does NOT report the readiness monitors. You need to use one of the relatively inexpensive readers available at most parts stores to see those monitors or just have any parts store read the emissions codes.
A drive cycle is a lot more than just one 5 to 10 mile rip up the Interstate. Requires a variety of driving including stop and go traffic and multiple ignition cycles.
if you know someone who has hptuners you can fix it easily by having them set all of your codes to "3- no error reported" and everything will instantly set to ready when the key is turned on... then after the inspection is done you can revert back to your previous settings... that is much easier than doing fancy drive cycles and wasting time, gas, etc
Will this work if there are no error codes, just the readiness monitors not setting?????
it should, my readiness monitors will automatically set as soon as the key is turned on... I have done it for a couple of friends that were having trouble and it worked, and like I said just revert back to your old settings afterwards... and when I said set all the codes I meant every single one of them, that way you don't have to worry about missing one
When you say "revert back to old setting afterward" what are you referring to. Are you saying that I need to install a new Tune? then overwrite it with the monitors reset?
yeah, pretty much... you aren't really changing the tune itself, you will just be setting the pcm codes to no error reported, load that onto your pcm, get your inspection, and then change the codes back to what they were before... you don't want to leave all the codes set to no error reported for a long time because if a real issue pops up you will get no cel and have no idea what is going on... this is just a quick way to get around the readiness monitors
You're talking the AIR and catalyst monitors. Same as others have posted, set all the AIR codes and rear O2 codes to no SES and no-error reporting and you'll be good to go. In all honestly, there is little point in setting them back later unless you care to get a code when the AIR system or rear O2 sensors are not working.
Thanks, now I need to find someone who can do that.
I'm moving your comment over to a thread that I created on my specific issues.
"George
If you don't have tuning software, you can purchase a phone APP that interfaces with a Bluetooth dongle that you plug into your ALDL Link that can show you ALL live sensor data and the status of your emissions status flags. Once you determine which emissions flag that is not setting, that will allow you to pin point the issue. You can also purchase an inexpensive scanner that can read live sensor data AND the emissions data flag status. That is the FIRST step in determining what is NOT Happy!
Bill"
As I stated above "I am trying to get my 2004 C5 through California emissions testing this year and have an issue with two readiness monitors not resetting, the Evaporative system and the Catalyst monitoring."
I have access to and have used an app to do real time monitoring of the System and they have continued to confirm the above sensors. I must admit though that I've not do this recently as for now the car is registered in a California county that is exempt from Smog requirements. With the information above I was advised to drive the car and perform the GM drive cycle which I had done several times but did not resolve the issue. I've had two tech tell me that until the monitors set they would not recommend going forward with any type of repair as that would just be shooting in the dark. Based on what you said above and knowing the two monitors what would you recommend as my next steps?
Any help would be greatly appreciated, While I am somewhat of a garage mechanic this type of issue is above my pay grade.
between 75-100 miles will need to be drive i. Order to get all monitors to turn on with the c5 corvette.
trust I've done my testing and compared it to another car i had.
Do yourself a favor and go for a nice drive in some back roads then freeway and lastly street. The o2 heaters take the longest to turn on.
Yeah i tried everything from letting the car idle for 1 hour to wot on the backroads and still didnt cut it lol.
