Half Shafts
Old Mar 19, 2016 | 05:33 PM
Bulldogger's Avatar
Bulldogger
Default Half Shafts
Have a problem with my 2003 Z06 clunking in the rear. I found that the rear spindle nut was loose on the passenger side. I torqued it to 118 ft lbs and took it for a ride. The clunk is still there. I noticed that the rear half shaft on the drivers side is tight with no play and the half shaft on the passenger side has some movement in and out when you grab it about an eighth of an inch. Should the half shaft have some movement or should it have no movement?
